Vagcom scan result? Air con not working
Danno57 Mar 17, 2013
  1. Danno57
    Danno57 Member VCDS Map User
    44
    Hi everyone, does anyone think they could do me the favour of looking over my fault codes and give me any guidance as to what I'd need to replace?
    The main problem is that my air con is not working, I've refilled the system with fresh refrigerant etc but the problem still persists. From looking at the fault codes I'm suspecting something is up with either the compressor or a leak somewhere?
    The second is the fault codes that's to do with the alarm system, as for this I have no idea what these codes mean or if its so serious my alarm wouldn't be triggered at all?
    & the last is that my airbag warning light is on, I've read up that this could be to do with the airbag wiring underneath the passenger seat coming loose or breaking?
    Thanks in advance :)
    -Dan
    Address 01: Engine Labels: 06A-906-019-AEH.lbl
    Part No: 06A 906 019 AM
    Component: 1.6l 2V/R4 SIMOS HS2585
    Coding: 04000
    Shop #: WSC 06313
    VCID: 6ED9EB722A0CEC68C39
    2 Faults Found:
    01013 - A/C Compressor Load Signal
    31-00 - Open or Short to Ground
    Readiness: N/A
    Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
    Part No: 8L0 820 043 D
    Component: A3 KLIMAVOLLAUTOMAT_D75
    Coding: 03141
    Shop #: WSC 06313
    VCID: 2953D86ED362CB5056B
    2 Faults Found:
    00792 - A/C Pressure Switch (F129)
    01206 - Signal for Duration of Ignition Off Time
    27-10 - Implausible Signal - Intermittent
    Address 15: Airbags Labels: 8L0-959-655-AI7.lbl
    Part No: 8L0 959 655 F
    Component: Airbag 7 Audi 0505
    Coding: 00104
    Shop #: WSC 06313
    VCID: 418360CE4B1223106EB
    2 Faults Found:
    00589 - Airbag Igniter 1; Passenger Side (N131)
    32-10 - Resistance too High - Intermittent
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8L0 862 257 P
    Component: CV-Pump, Alarm, RC D13
    Coding: 13130
    Shop #: WSC 06313
    VCID: 42816FC24E143808771
    12 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    00991 - Interior Lights
    28-00 - Short to Plus
    00955 - Key 1
    09-00 - Adaptation Limit Surpassed
    01134 - Alarm Horn (H12)
    76-00 - Terminal 30 missing
    77-00 - Internal Supply Voltage
    49-00 - No Communications
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 06313
    VCID: E0C5054A60D8CA18C15
    1 Fault Found:
    01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
    35-00 - -
  2. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    ok so first off you either have a pressure sensor fault or a low gas pressure (that will display a pressure switch fault)
    as for the rest clear the codes and see what comes back
  3. Danno57
    44
    Thanks for that Phil, I will do as suggested. Today I tried to refill the refrigerant again, the pressure gauge went up to the green zone so I stopped and disconnected it, immediately though it dropped back to 0 over a minute or so, so there must be a leak!
    -Dan
  4. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,820
    197
    [h=4]Airbag issue:
    Possible Causes[/h]
    • Wiring from/to Airbag Igniter Passenger Side (N131) faulty
    • Airbag Igniter Passenger Side (N131) faulty
    [h=4]Possible Solutions[/h]
    • Check Wiring from/to Airbag Igniter Passenger Side (N131)
    • Check Airbag Igniter Passenger Side (N131)
    [h=4]Special Notes[/h]
    • When "Short to positive" or "Short to ground" is found, DO NOT CLEAR THE DTC. This can cause the airbag to deploy. See repair manual for more information.
    Aircon:
    [h=4]Possible Causes[/h]
    • A/C System Malfunctions
      • Over or insufficiently charged
      • Refrigerant System blockage
      • Insufficient Air Flow to Condensor and/or Engine Radiator
    • Wiring to/from A/C Pressure Switch (F129) faulty
    • A/C Pressure Switch (F129) faulty
