VAGCOM results
kitpayne Sep 18, 2009
  1. kitpayne
    kitpayne Member
    129
    Hey all. I just received my VAGCOM lead - the one from ebay. I just got it working - on the limited version and this is what it said.
    VAG-COM Version: Release 409.1-US
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
    Address 01: Engine
    Controller: 8L0 906 018 K
    Component: 1.8L R4/5VT 0003
    Coding: 05610
    Shop #: WSC 06435
    6 Faults Found:
    17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
    P1340 - 35-00 - -
    16795 - Shareware Version. To Decode all DTCs
    P0411 - 35-10 - Please Register/Activate - Intermittent
    17925 - Shareware Version. To Decode all DTCs
    P1517 - 35-10 - Please Register/Activate - Intermittent
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    16486 - Shareware Version. To Decode all DTCs
    P0102 - 35-10 - Please Register/Activate - Intermittent
    18017 - Shareware Version. To Decode all DTCs
    P1609 - 35-00 - Please Register/Activate
    Readiness: 0000 0000
    Address 03: ABS Brakes
    Controller: 8N0 907 379 C
    Component: ABS/EDS 20 IE CAN V003
    Coding: 13504
    Shop #: WSC 06435
    1 Fault Found:
    01324 - Control Module for All Wheel Drive (J492)
    49-00 - No Communications
    I read somewhere to clear them and check again some when else. Should i do this, as they could be old faults, or should i check out the problems? Think i'm gonna have to buy the licence!!
    Also what other sort of useful stuff can i do with the software?
  2. NHN
    29,295
    1,701
    Clear & then drive & check again cause camshaft one wont come back until driven for very short distance but will show up again given I had this, then come back with list to us..
    If you ever want a genuine cable then PM me as I sell these.
  3. kitpayne
    kitpayne Member
    129
    ok cheers. that was what i thought, just didn't want to go tinkering and f*!k it up. Will post new results wednesday as am working til then. cheers :icon_thumright:
