Seems a touch low doesnt it?
Stock sized turbo made that sort of power on about that boost did it not? That said, my turbo is bigger than a F21 IIRC, so it makes sense that i'd be making more power.
Your log isnt ideal as its not one nice solid pull.
What you want to do is get it in 3rd gear, 2000rpm, and floor it right thru the rev range. Then lift and stop logging or set a marker. That way you can focus in on just that section of the pull. Do it while only logging MAF and maybe ignition timing so you get the better resolution.
If your ECU is stock (not remapped) You could try reconnecting the N75, but be VERY careful as you could see huge boost spikes. Because the ECU thinks your only making 150hp, it'll turn the boost up to get what it thinks is 180ish. Personally i'd just leave it as it is until you get it mapped. That said, mark ran his with the N75 connected when he had a similar hybrid without any issues, he did get some silly boost spikes to 1.4 bar though if i remember correctly.
