Vagcom / home logging
jonny87
worcester
well seeing as ive decided i cannot bring myself to part with the audi, i think i would benefit greatly from having my own vagcom and being able to do some of my own logging, as most of the problems i post up are easier explained/diagnosed with facts and figures to back it up
i have this link saved: http://www.vagproducts.co.uk/vagcom.html
is it really just a £20 cable? surely it costs more / there is more to it?
thanks in advance :)
Looks like it only works with earlier shareware versions of VAGCOM which will give limited functionality.
You can get the earlier version of VAGCOM to use with ebay/third party cables here...
http://www.ross-tech.com/vcds/download/index.html
All later versions use a dongle based approach to licensing with the cable so you effectively get a full version of VCDS for free if you by a licensed cable. Thats not cheap however...
You can buy a license for VAGCOM for $99 if using a third party cable but not sure what version that entitles you too....
http://www.ross-tech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=VSWR&Category_Code=VAGCOM
..,also very restrictive and you can only use it on one PC... proper cable allows you to use it on any PC running VCDS.
VCDS from Ross-Tech was the first thing I got when I bought my S3, its saved me hundreds of squids in diagnostic charges and has helped me diagnose loads of issues on my friends VAG cars.
I paid almost £300 for the package as it comes from the US and you have to pay some import duty tax too! It's paid for itself in a year though. If I ever sell my car and dont get another VAG car these cables re-sell quite well 2nd hand so I wont loose too much cash.
yer see this is my thinking, not only can i self diagnose, but doing all the logs will help me btter understand what is going on with my motor
alot of places will charge £50 just to plug vagcom in!!!
yer i think the vcds actually works out to £220 and then as you say theres import/duty tax to pay, its defo something im looking into
i may look at a 2nd hand one and then pay the $99 license charge, see if it works out any cheaper
thanks for the replies you two :)
actually i just found this on ebay: http://cgi.ebay.co.uk/VCDS-VAG-COM-...iagnostic_Tools_Equipment?hash=item27aeae3b52
underneath the list of applications it says to never update the software, whats that all about? is that right? it seems a bit too cheap to be everything i wanted?
im guessing canbus is what newer models use, like the 8p s3? and that k line would be the 8l era and earlier?
the two main things i want is code reading/resetting and live logging, i may well go with the one i linked above, but if not i will look into the one you have tuffty
22
964
540
