VAGCOM Error on ABS brakes
VTEC_Killer Oct 24, 2012
  1. VTEC_Killer
    VTEC_Killer Member
    92
    Can anybody help with the following error code from VAGCOM:
    Address 03: ABS Brakes
    Controller: 8E0 614 517
    Component: ABS/ESP front 3429
    Coding: 04255
    Shop #: WSC 06435
    1 Fault Found:
    65535 - Internal Control Module Memory Error
    00-00 - -
    I've cleared it and it now gone, but I've never had a issue with the brakes so surprised this error has been logged.
    Thanks!
  2. quattrojames
    14,060
    583
    Probably a blip in the controller one cold morning when starting or something, I wouldn't worry if it doesn't return.
  3. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    I had this once
    One morning on a very cold day I had the red brake light on the dash at start up which I think caused it as the fault its caused by lack of power to ABS module and the brakes warning is because of a lack of power too!
    I cleared the fault and not been back once
