VAGCOM BRAKE BLEEDING
HOTTIGGER May 7, 2012
  1. HOTTIGGER
    HOTTIGGER Member
    99
    hi all, can i bleed my brakes with vagcom? ive broke 1 of the small bleed nipples of the master cylinder while trying to bleed my brakes, and i need to no if you can bleed them through vagcom with out having to change the broken bleed nipple on the m/c. thanks..
  2. bluequattro
    bluequattro Member
    411
    Im sure theres a procedure on rosstechs web site m8,
    im sure its really only for complete brake refurbs?
    Still worth a look tho.
    Cal
  3. NHN
    29,596
    1,782
    Yes but the bleed nipple is to allow the fluid to come out, thats the point of bleeding as you know, you can certainly do it via vcds & bleed through the calipers, but it may not bleed the mc properly if you've introduced air into the mc circuit as such, check to see if the nipples can be replaced independently, if so replace & bleed again.
