VAG scanner tool.
Lee Goodall
UK - Midlands
Found a VAG memo scanner (hand held OBDII socket powered) tool which has the following features:-
Control Unit Information
Read Fault Codes
Measuring Blocks
Clear Fault Codes
Basic Setting
Adaptation
Single Reading
Output Tests
Code Module
Login
Service Oil Reset
Code Modes
Dealership Code Set
Sound any good? I've not got a laptop so seems like a good alternative to VAG-COM.
i think pre 99 cars aren't fully obd2 compliant, so just check it works ok on these if your car is.
Really?!.. didn't know that. That must be why I'm having so many problems trying to get vagcom to work.
I don't see why - VAG-COM works on all models.
How much is the other scan tool, out of interest?
Read Fault Codes
Measuring Blocks
Clear Fault Codes
Basic Setting
Adaptation
Single Reading
Output Tests
Code Module
Login
Service Oil Reset
Code Modes
Dealership Code Set
Doesn't actually state 'ODBII' but does say works with all VAG cars!
possibly incorrect cable, not sure.
i think the stand alone unit will work
15
4K
545
