I have posted this on navplus forum but I may get just as much help here maybe more.
I was checking to see what cabling was behind my dash over the weekend to see what kind of work needed to be done for a Nav+ project.
The dash removal went fine no problems I unplugged the 3 sockets from the back of the dash and then had a good look around.
I put all the sockets back into the dash and the screwed the dash back into place.
Everything seemed fine the radio worked ok etc.
When I tried to start the car it took maybe 8 tries felt like the battery was low or something (which it isnt) car started and everything seemed fine.
As I was driving I went over a bad bump in the road and the radio went blank and the sound cut out there is a mecahnical noise coming from the radio and thats all.
If I slap the radio it will come back on also if i slap the dash the radio will come back on too.
I checked all the cables again and everything seems fine.
So I did a vag scan yesterday to see what errors it might find and it threw up a few that I am very worried about.
Here are the errors it found.
Address 01 -------------------------------------------------------
Controller: 4B0 906 018
Component: 1.8L R4 5VT 01 0004
Coding: 05001
Shop #: WSC 06335
2 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
18084 - EPC Warning Lamp (K132) Circuit: Electrical Malfunction
P1676 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 56 -------------------------------------------------------
Controller: 4B0 035 186
Component: Radio 0001
Coding: 00207
Shop #: WSC 06335
1 Fault Found:
00854 - Radio Display Output in dash Panel insert
49-10 - No Communications - Intermittent
Does anyone know what is causing these errors and how it can be fixed?
I hvae cleared the faults but they still come back.
Coding: 05001
Shop #: WSC 06335
2 Faults Found:
Coding: 00207
Shop #: WSC 06335
1 Fault Found:
