VAG Descriptions - what do they really mean?
Discussion in 'VCDS (formerly VAG-COM) forum' started by kaos_king, Aug 13, 2008.
  1. kaos_king
    kaos_king New Member
    Feb 2, 2008
    10
    Ive got afew problems with my 2002 A3 1.6 sport.
    Linked it up to VAGCOM and got the codes but im not entirely sure what they mean. Im quite mechanical minded, but more to the older/pure mechanical cars and not the electronic age!
    Any help would be greatly appreciated, on the actual problem/resolution and estimated cost.
    1) F265 - Map Controlled Engine Cooling Thermostat
    Obviously a thermostat problem, swap it out for a fix? where's it located?
    2) P1176 - Bank1 02s (lambda) Correction Behind Catalyst: Control Limit Reached
    Problem with the lambda sensor - what does the limit reached mean, can i just clear the limit electronically, or (and i hope not) do i need a new lambda sensor?
    3) P1650 - Powertrain Data Bus: Missing Instrument From Cluster
    No clue on this one.
    As said, any help would be massivly appreciated! Cheers! :beerchug:
  2. Advert Guest Advertisement
  3. benr
    benr Member
    Jan 21, 2008
    819
    Surprised no one has answered yet, id try posting in A3 forum it gets more coverage. Or ross tech wiki page has info on fault codes.
    Only thing i would say is to clear all the coded then check it in a couple of days to see what is actually a problem as these could have been logged long ago and are not actually current problems.
