  1. b00zehound
    b00zehound Member
    90
  2. jase0851
    jase0851 Member
    789
    these are £250 from rosstech arnt they
  3. quattrojames
    14,050
    578
    It doesn't include the B6 chassis in the compatibility chart though.
  4. evilscotsman
    evilscotsman Space Cowboy
    1,350
    14
    you need the hex-can-usb interface, that works with almost everything.
    Still doesnt get you a licence from rosstech since its not coming from them, but may still unlock the full program (in a kind of illegal sort of way lol) - the one I got from china does. Mine was fatally wounded by the rosstech 704 upgrade, but may be fixable / half fixed. I only paid £19 for mine but it only worked with versions 409 and 607, though that was more than enough.
    fleabay is full of replicas now, just buy the cheapest hex/can/usb one you can find, and get the freeware version of the program it needs. rosstech no longer give out ver 409 (maybe not even 607) due to the issues with copied cables (which arent illegal - not copyrighted or patented, existing technology and all that) but their software can only be unlocked by a "genuine" cable......enter the chinese :)
    And you can get the software from some other sources, some come from fleabay with a disc.
  5. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,385
    112
    quattro,
    why is this ?
    does it mean it only works on 100% canbus cars, i thought ours had canbus or is it k-line
  6. evilscotsman
    1,350
    14
    dual k-line I think mate, and weird timing issues in the protocol.
  7. quattrojames
    14,050
    578
    :search: It's all Greek to me dude, sorry!
  8. Marc1
    Marc1 Member
    728
    HEX-CAN is what we need sadly, otherwise I'd be bidding on that one!
  9. 1wheelonly
    2,385
    112
    lol. your not on your own mate, ive got vagcom and i still dont understand it.:banghead:
  10. jase0851
    jase0851 Member
    789
    i was under the impression the authenticity code was imprinted into the genuine cables ? as you can download vag-com for free
  11. Tendaimwari
    Tendaimwari Member
    124
    The new cables come with an in-built dongle so no need for activation. Also you can still get shareware copies of 409 from the ross-tech site.
  12. aragorn
    18,491
    855
    I think the cheap ebay leads and shareware software should work fine on a B6, as its not CANBus, its K-line.
    You can get a licence from rosstech to use the cheap ebay lead with their 409 software for £70, which gives you a fully legal, activated setup for under a hundered quid. I would only go for the expensive kit if you can really justify the extra cash, because even if the ebay lead fails, the difference in price buys you many replacements.
  13. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    B6 needs ONLY dual K-line, B7 needs dual K-line plus CAN.
  14. technics100
    technics100 Active Member
    850
    25
    So will a cheap cable with 409.1 give full usability ? I have a copy of 409.1 and a cheap lead, will this let me do output tests etc etc.
  15. evilscotsman
    1,350
    14
    if the lead is the smart kind and can unlock the program, you will know because on the config screen it will tell you. Only after using the lead on a car though, it wont register when its not connected to a motor.
    It doesnt record anything, its just only meant to operate connected to the car so thats what you do, then run the reg test (you'll see what I mean) and viola.
    Dont want to go into more detail but its not hard to get them set up, then read the rosstech wiki to learn codes, fault reasons and config tips for the car's adaptable settings, everything works with a cable thats used with the version it is said to need by the seller.... ;)
  16. aragorn
    18,491
    855
  17. PetrolDave
    1,559
    85
    I'd love to see you recode the Audi phone module using 409.1...
    That's a b.tch of a module to recode with any version earlier than 6xx, and only 7xx or 8xx are totally reliable.
    What about the engine and multi/tip-tronic gearbox controllers on a B7 A4? - they have CAN bus diagnostics not K-line, so you need a CAN capable lead to access them.
    Plus ALL the diagnostics on an 8p A3 are on the CAN bus.
    Any lead without CAN bus might be fine on a B6, but when you come to geat a B7 or any newer Audi you will need a lead that's dual-K + CAN capable.
  18. hutchybee
    hutchybee Faux Musician
    85
    Sprachen sie english?!:confused::laugh:
  19. aragorn
    18,491
    855
    Oh for sure.
    Its been said a few times in this thread though that the B6 is K-Line only and will be fine on the cheap leads.
    Bar the phone module, which i wasnt aware of, the cheap lead is in my opinion MUCH better value.
    Not only does it mean you can get the entire kit up and running with full functionality for £85, but rosstech also give you the value of the licence as a discount off buying their full hardware, so should you need to upgrade to the official kit at a later date due to having a car that requires CAN your only £15 worse off...
  20. Marc1
    Marc1 Member
    728
    So does 409 allow you to log live data - dyno runs, turbo vnt actuator movement, boost levels, egr range of motion, code rns-e etc, etc? All with a cheap cable?
  21. aragorn
    18,491
    855
    It certainly does all the logging etc with the full licence. I've done a number of logging runs on both my bro's S4 and our 1.8T which worked perfectly. The only thing you dont get is the "Turbo" mode for faster sampling, as this only exists in later software.
    Not tried to recode an RNS-E with it, however i have recoded the central locking controller without any problems.
  22. PetrolDave
    1,559
    85
    Depends how much value you place on your own time.
    I've read lots of people having problems with USB versions of the cheap leads haviong to uniinstall and re-install the USB drivers almost every time they try to use the lead.
    Personally I want the lead to work every time I need it to check/fix something on my car and I don't want to waste time messing around with the PC.
    With that plus I do a lot of setups of the Audi phone module, so for me there are two reasons why I think the genuine Ross-Tech leads are the best value, they're not cheap but they're hassle free.
  23. aragorn
    18,491
    855
    Personally i've only had very mild issues, usually with windows allocating the USB->Serial Bridge a Com port number over 4, which vagcom cant see. Only takes seconds to change it to a lower number though, and as long as you use the same USB port each time it doesnt usually forget the altered allocation.
    I guess it depends how comfortable you are tinkering around in the device manager etc, however i do feel that for most people, who are mostly going to use it to pull codes and perhaps log some data now and then the cheap leads are good value.
    I guess its upto the person making the purchase to choose, all i'm trying to do is correct the misinformation that was at the start of this thread claiming the ebay leads were junk and a waste of time etc.
    The simple fact is that for £85 quid your getting MOST of the functionality of the real lead, while saving yourself a lot of money, plus, you've always got the option of upgrading to the real kit, and getting the money you spent on the licence offset against it, which in my eyes makes it an even better deal.
  24. PetrolDave
    1,559
    85
    We can agree on that, it's just that most of the things I do with a VAG-COM lead need the things that are not in the MOST subset of the cheap leads so for me they would be a waste of money. But that wouldn't be the case for most people...
  25. jase0851
    jase0851 Member
    789
    i got a cheap lead of ebay downloaded the free copy off rosstech and input a licence and its worked ok for me
  26. johnp68
    johnp68 New Member
    ditto here
  27. evilscotsman
    1,350
    14
    mine also unlocked the whole functionality so I was missing nothing. Just dont try to run the cheap cable with ver 704 of vag because it has an auto update feature that writes to the eprom chip in the cable head, and will bugger a copy cable completely.
    stick to the version intended for the copy cable, up to 6xx worked ok for me, 7xx doesnt.
    You can however copy over the definition files from ver 7xx and place them in the 6xx directory in the correct folder, giving even more named labels and info learned for the later build, they work fine same format.
  28. Marc1
    Marc1 Member
    728
    So has anyone done any live readings with the cheap cables? I really need this functionality, however I'm holding back on stumping up the full £250+ for a full version and lead as this car seems to be costing me a packet!!!
  29. technics100
    850
    25
    Yes, I have done logging with my brothers 1.8T, boost levels, air/fuel etc etc while driving. Thats with 3.11 fully registered. PM me if you want it...
  30. Marc1
    Marc1 Member
    728
    Thanks Technics100. Now I'm confused again - 3.11?
  31. evilscotsman
    1,350
    14
    Yeah 311 was specified for some early cables. It works fine, and should also work with 409 and 607 too, ie if the cable works with 311 it should work with the others below version 700.
