  1. s3_stig
    s3_stig Member
    376
    Address 01: Engine
    Controller: 8N0 906 018 J
    Component: 1.8L R4/5VT 0004
    Coding: 10710
    Shop #: WSC 01236
    WAUZZZ8LZ11000797 AUZ7Z0A1825268
    1 Fault Found:
    16706 - Engine Speed Sensor (G28): No Signal
    P0322 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes
    Controller: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 01236
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    27-10 - Implausible Signal - Intermittent
    can anyone help with these vag com results I got the other day please
  2. s3_stig
    s3_stig Member
    376
    Someone please help me out thanks
  3. thorsy22
    thorsy22 Member
    308
    Pretty sure I had that steering angle sensor fault, means its knackered. You can watch/log the steering angle sensor but can't remember which block it is. The value should chamge when turn the wheel, if the value is fixed like mine was you'll need to replace it. Just under 200quid from stealers iirc.
  4. s3_stig
    s3_stig Member
    376
    Why is everything so cheap
    cheers mate for the info
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    i would delete your chassis number too :icon_thumright:
