VAG-COM Programming New Key?
Haroulli Dec 29, 2006
  1. Haroulli
    Haroulli Member
    31
    When i bought my A4 B6 it only came with one key.
    I bought a key for my year and model from eBay and the guy assured me it would have the right transponder in it for my car and that all i needed is to get it cut.
    Once cut and i stick it in the door and the original remote i the ignition and do the programming it should work right?
    However, after looking at VAG-COM Wiki i found this:
    Does this mean i have to program the key to the car via this method? Does this automatically pick-up the key, to remote unlock and lock?
  2. Sebastian
    Sebastian Member
    286
    The procedure you are pointing to is only suitable to match the remote, not the immobilizer. The door lock procedure is normally only to re-synch an already matched remote.
  3. Haroulli
    Haroulli Member
    31
    Seems like i've got my self into a delicate conumdrum!
    I've tried the VAG-COM procedure to no avail.
    Can only dealers register it to the immobilzer?
  4. Uwe@Ross-Tech
    Uwe@Ross-Tech Member
    130
  5. Haroulli
    Haroulli Member
    31
    **** so even if i get someone to cut my key i'll still need to go to the dealer to get it programmed to the car.
    I could do what you listed in the link but i doubt my dealer will give me those codes. My Audi dealer kinda sucks as they've only been open a little over 2years
    Do i need the PIN and the SKC or one or the other?
    When it says:
    "Allow the car to sit for AT LEAST the number of minutes that were indicated by the display in Group 024"
    It basically means if it says 12 i've got to wait 12 minutes before i can do anything?
    First thing's first i need to get my key cut! Now, i've found someone who lives in my complex that is a Locksmith that can do it but wants $100 just to cut it! Is this about right? Thats about 60pounds.
    I'm starting to think the dealer is a better choice!
  6. awmw
    awmw New Member
    24
    I went through this myself.
    I went to a local lock smith that specialised in car security.
    They had a handheld box of tricks that pluged into the OBD port and read the SKC from the ECU.
  7. Haroulli
    Haroulli Member
    31
    Hmm does that mean it can be read with VAG-COM?
    Anyways i think i'll give this guy whoes potential be able to cut my key to see if he can program it to the Immobilizer too. He sounded like he knew what he was talking about!
  8. bearthebruce
    bearthebruce Ross-Tech, LLC
    343
    21
    As Uwe told you, VAG-COM cannot get the SKC. The programs locksmiths use are different.
    VAG-COM can program the key if you have the SKC. The dealers used to give these out to the owner of the vehicle but they no longer have the means to see the SKC. So they no longer can give you that information.
  9. ibzuk.com
    ibzuk.com New Member
    9
    hi what year is your audi a4 b6? i may be able to help you i may be able to program your key to your car i have means and ways to extract your skc from your car.im based in stoke on trent if this helps you.:arco:
  10. Haroulli
    Haroulli Member
    31
    Haha hi, my cars a 2003 but i live in Charleston South Carolina, i just moved here i'm an expat from Cheltenham, Glos.
    Would have a been a good help we were in the same country, nevermind! Thanks for the help though!
  11. Sinny71
    Sinny71 S55 LKS
    779
    Out of curiosity, what does the PIN/SKC code look like?? I got a plastic key and keyring with the car and was wondering if thats what was noted on there.
  12. ibzuk.com
    9
    skc/login is usually on a scratch off panel 4 digits
  13. Haroulli
    Haroulli Member
    31
    wheres the scratch off panel? I think i just read somewhere else that on pre March 2002 cars. Mine's a 2003 but if i know what to look for i'll take a look!
  14. Uwe@Ross-Tech
    130
    The scratch-off tag supplied with some cars looks like this:
    However, I'm sure 2003 model Audis did not come with these.
    -Uwe-
