Vag-Com problem on a new laptop with vista
Badgeronimous Dec 14, 2007
  1. Badgeronimous
    Badgeronimous New Member
    Anytime I try to run vag com, I set it up then start running the auto check/scan facility (I can't seem to switch my traction control on so want to find out why), it starts the test then within 10 secs of it starting I get ''program has stopped working''
    I'm using version 409, with a third party cable (that does work as the guy I've borrowed it off uses it regularly), running Vista home edition on a brand new laptop. The car is an '01 S3.
  2. Badgeronimous
    double post sorry
  3. steve1975l
    steve1975l Member
    595
    I had the same problem so I bought a real setup. I would borrow your friends laptop as there seems to be some USB driver problems with Vista.
  4. rodenal
    rodenal Active Member
    1,992
    I would try it on an xp laptop, vista is the work of the devil lol
  5. mavala
    mavala Oops!!!!
    39
    Only Vag Com 704.1 works with Vista.
    You will also need to replace the KKL cable with an HEX CAN USB cable
  6. j4jon
    j4jon Member
    704
    I have a laptop running Vista using version 311 and a 3rd party cable seems to work fine
