Vag Com Logging which measuring blocks tell me if the car is doing what it should??
S3 Paul Jun 7, 2010
  1. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,824
    107
    I did a few searchs ( before i get told off )
    But i didnt realy find a straight forward answer...
    My car is a 2001 S3 with a few mods and a phase 3 map,
    I have vag com ... i think its only the 311.2 version or something and just wondered which groups of 3 measuring blocks i should log together to show wether the car is running spot on and if it has been mapped correctly.
    Also... once i have logged these blocks how do i go about posting the logs so people alot cleverer than me can take a look??
    Many thanks :sos:
  2. finesse
    finesse Active Member
    2,805
    From 3rd gear, 2000rpm to redline
    1. 002 031 115
    2. 002 115 119
    3. Take note of the two values of block 032 when idling after the run
    002 : Airflow
    031 : Lambda actual value vs Lambda specified value
    115 : Boost pressure specified value vs Boost pressure actual value
    119 :
    Duty cycle boost pressure control valve vs Boost pressure before throttle valve
    ps is your S3 really pink?
  3. S3 Paul
    2,824
    107
    Thankyou,
    Although i wish it was... its not..
    and its not realy got as much power as my sig says...
    Its much less :laugh:
  4. S3 Paul
    2,824
    107
    So which blocks would you log to show if an intercooler upgrade was working well?
    Intake temps v ??
  5. <tuffty/>
    20,995
    3,762
    Block 118 will give you AIT's, will also show actual boost too so you can see how AIT's are affected under boost... logging block 020 is useful while doing AIT's as you can see if any timing pull you get maybe related to higher AIT's... Block 112 gives you EGT's....
  6. S3 Paul
    2,824
    107
    Thankyou paul.
    Hoping this will help others too
  7. sportstractor
    sportstractor Chugger
    2,709
    tuffty what would you consider a unhealthy timing pull. After logging mine I was getting a 6-7 on cyl 4, and 4-5 on cylinder 3 between 4100 - 5200 rpm? Cyl 1 and 2 remain on zero
  8. <tuffty/>
    20,995
    3,762
    3's ideally, 6's at a push (as long as its not all the time) but if you get more I would look into why you are getting them...
    Timing pull is going to be more in the hotter weather unless you have a good FMIC... recent S3 in the workshop had an APR stage 2 but didn't have a FMIC fitted... was pulling 9's IIRC... ouch!
  9. Westy
    Westy Well-Known Member
    17,443
    1,103
    That's good to know. I was pulling 5.3 at 20 degrees AIT on one cylinder! That was back in Feb. I think its time for that FMIC
