VAG-COM in South Yorkshire ?
Whiteatom Sep 5, 2008
  1. Whiteatom
    Whiteatom Member
    98
    Just had BOSE removed and had aftermarket kit fitted but now need GALA en-ableing via vag-com.
    Anyone in the area that could do a good deed for some beer or cash ?
    Will be posting pics of new install inc my custom made sub box c/w JL 8" sub behind original trim.
    If anyone can help please contact me.
    Cheers Matt
  2. Von Maximo
    Von Maximo The Damned
    344
    PM sent
  3. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    what head unit do you have? you can enable GALA from the system menu on most Audi head units.
  4. Whiteatom
    Whiteatom Member
    98
    Have RNS-E which did have BOSE + audio pilot thus no option for GALA in menu.
    The RNS-E needs re-coding for GALA
  5. JohnS3
    JohnS3 Active Member
    3,032
    You might want to experiment with removing the Bose wire so you don't get the Bose EQ settings. Although I'm unsure if the EQ is done in the RNSe or the now removed Bose amp. Does anyone know for sure?
  6. Whiteatom
    Whiteatom Member
    98
    Yes I need to disconnect the BOSE wire, some views are that it alters the EQ from the RNS-E and en-ables the internal amp (not used in my install) others say that the EQ can only be altered through coding.
    Either way I need to en able GALA as was done through BOSE audio pilot which is now removed.
    Will update you when I find out
  7. Whiteatom
    Whiteatom Member
    98
    Just disconnected the BOSE wire and can confirm it sounds miles better , both Bass and treble control on the RNS-E work !
    Disconnect BOSE wire = Better sound , better EQ :jump:
  8. Whiteatom
    Whiteatom Member
    98
    Sorted now, big thanks to Von Maximo !
    Thanks again
  9. Von Maximo
    344
    My pleasure mate, Anytime you want it doing again you know where I am!
  10. Kontraband
    Kontraband Active Member
    2,003
    Where ARE you??
  11. Whiteatom
    Whiteatom Member
    98
    Rotherham, Van Maximo may need you quicker than you think, just tried reversing tonight and does not recognise reversing sensors now !
    Will give u a bell
  12. Kontraband
    2,003
    Ahhh Roth Vegas... :)
    Both of you?
