vag com - ignition short to ground
sun and kath
Hi got an intermittent misfire, just pulled this code
17771 - Cylinder 3 Ignition Circuit: Short Circuit to Ground
P1363 - 35-10 - - - Intermittent
any ideas?, could it be the plug? or the coil ?
:sob:
sounds more like the ignition driver itself
Sits atop the airbox.
The ECU cant "see" the coils, so for it to notice a problem it must be the driver i recon.
thanks for the pointer
i 'll check out the cost
anything i can do to be sure?
there are two modules there, one for each bank, swap them over and see if the fault moves. That should help eliminate the ICM
31
7K
948
N8
799
jcb
10
