Vag-Com Error
aristides Jan 8, 2010
  1. aristides
    aristides Member
    550
    Hola folks.
    Popped my VCDS prog today to do some work , and noticed this Engine Error.
    I know its intermittent, but i never felt anything going wrong with the car
    Should i go check it?
  2. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,380
    214
    I wouldnt worry, clear the fault code and see if it comes back. If the Oxygen (Lambda) Sensor fails you will get an engine warning light but it will still drive ok so you will not be stuck. this cold weather plays havoc with the electrics. My Vagcom says i have a failed glo plug pre heater indicator.....and i dont have a diesel....
    Address 01: Engine Labels: 022-906-032-BDB.lbl
    Part No SW: 022 906 032 CB HW: Bas isX 3
    Component: MOTRONIC ME7.1.1G 5604
    Revision: 00000000 Serial number: AUX7Z0D2FN40HY
    Coding: 0000178
    Shop #: WSC 00000 000 08192
    1 Fault Found:
    18025 - Glow Plug Pre-Heat Indicator (K29): Open or Short to Ground
    P1617 - 001 - Upper Limit Exceeded - Intermittent
    Readiness: 0110 1101
