VAG.COM error codes - Any ideas ?
sbk1972 May 4, 2009
  1. sbk1972
    sbk1972 New Member
    13
    Hi all
    Recently had the car connected to a VAG.com diag. Had the following codes, any ideas ?
    AFTER
    VCDS Version: Release 805.1
    Data version: 20090213
    Monday,04,May,2009,12:04:38:15823
    Chassis Type: 4B - Audi A6 C5
    Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
    76 77
    Address 01: Engine Labels: 059-907-401-AKE.lbl
    Part No: 4Z7 907 401 A
    Component: 2.5l/4VTEDC G000AG D00
    Coding: 01016
    Shop #: WSC 02325
    Part No: 00014059
    Component: 130 106EC150_1.R75146693087
    WAUZZZ4BZ1N048236 AUZ7Z0Y1557244
    2 Faults Found:
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-00 - -
    18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
    P1650 - 35-10 - - - Intermittent
    Readiness: N/A
    Address 02: Auto Trans Labels: 01V-927-156.lbl
    Part No: 4Z7 927 156 D
    Component: AG5 01V 2.5lTDI RdW 1010
    Coding: 00001
    Shop #: WSC 00000
    1 Fault Found:
    17125 - Torque Converter Clutch: Stuck OFF / No Power being transferred
    P0741 - 35-00 - -
    Address 34: Level Control Labels: 4Z7-907-553.lbl
    Part No: 4Z7 907 553 A
    Component: - 2C1A1 X030
    Coding: 25500
    Shop #: WSC 00216
    2 Faults Found:
    01577 - Turn-Off due to Over-Temp
    01772 - Signal from Level Control Pressure Sensor (G291)
    27-10 - Implausible Signal - Intermittent
    Any one got an idea ?
    SBK
  2. Andrew457
    Andrew457 New Member
  3. Cockney Boy
    Cockney Boy Member
    483
    have you done anything to the car recently to cause these codes?
