  1. voteforpedro
    voteforpedro Member
    632
    That was fun!
    VAG-COM Version: Release 409.1-S
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,17,25,35,45,55,56
    Address 01: Engine
    Controller: 8D0 907 557
    Component: 1,8l R4/5VT MOTR HS D05
    Coding: 04001
    Shop #: WSC 00000
    7 Faults Found:
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - - Intermittent
    16885 - Shareware Version. To Decode all DTCs
    P0501 - 35-10 - Please Register/Activate - Intermittent
    00532 - Shareware Version. To Decode all DTCs
    07-10 - Please Register/Activate - Intermittent
    17733 - Knock-Control: Cylinder 1: Regulation Limit Exceeded
    P1325 - 35-10 - - - Intermittent
    17734 - Shareware Version. To Decode all DTCs
    P1326 - 35-10 - Please Register/Activate - Intermittent
    16500 - Shareware Version. To Decode all DTCs
    P0116 - 35-10 - Please Register/Activate - Intermittent
    00670 - Throttle Position Sensor (G127)
    27-10 - Implausible Signal - Intermittent
    Readiness: N/A
    Address 03: ABS Brakes
    Controller: 4D0 907 379 D
    Component: ABS BOSCH 5 4174
    Coding: 0265108005
    Shop #: BB 34174
    No fault code found.
  2. aragorn
    18,315
    809
    if you fire over to rosstechs website you can convert those Pxxxx codes into the real fault codes and see whats really going on.
