VAG COM codes
hammondr
Control Module Part Number: 06A 906 019 AM
Component and/or Version: 1.6l 2V/R4 SIMOS HS2585
Software Coding: 04000
Work Shop Code: WSC 06313
2 Faults Found:
00668 - Supply Voltage Terminal 30
36-10 - Open Circuit - Intermittent
Control Module Part Number: 1J0 907 379 G
Component and/or Version: ABS 20 IE CAN 0001
Software Coding: 03504
Work Shop Code: WSC 06435
1 Fault Found:
16-10 - Signal Outside Specifications - Intermitten
From what I understand they are built into the parts they control, one of the codes has ABS prefixing, the other 1.6l so I assume you have a 1.6ltr A3? I would check the earths under the battery tray as a starter... Need to remove the battery and the battery tray IIRC...
do you think rhat would stop the engine turning
Well given its mentioning terminal 30 electrical circuit errors then yes that could very well take out a number of important systems, check the wiring as already advised cause open circuit is 99% time a wiring issue, loose or broken wire.
Given the starting issue, I would get the battery checked out too.
3K
3K
891
570
