VAG Com and Cruise Control
S-T Aug 14, 2006
  1. S-T
    S-T New Member
    15
    A couple of questions for the brighter people on here.
    Is the code to enable cruise control
    engine 01
    login 11
    11463
    And is there anything else that needs enabling on a new steering wheel controller ?
    Many thanks
  2. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,415
    2,979
    Sorry. I can't help you, as I am one of the dimmer people on here.
  3. S-T
    S-T New Member
    15
    me too, thats why i need help !
  4. shark_90
    shark_90 Member
    96
  5. S-T
    S-T New Member
    15
    Right changed the steering control module, the abs warning lights are all on. will changing the code on the engine login clear this as to be honest this bit on tyresmoke about the DIS just confused me even more.
    which bits are relevant if you havent changed the DID just added a module and a cruise control stalk ?
    Many thanks
    p.s. after looking at some of the settings I think i might need the full version of VAGCOM am i right ?
  6. shark_90
    shark_90 Member
    96
    I'm afraid you definately do need a full version of VAG-COM, yes. Your ESP and all related systems won't work until you've recoded the steering wheel control module and ESP controller as per the link I posted. You can only do that with a full version.
    Just coding the Engine ECU with 11463 won't turn off the ABS warning lights.
  7. S-T
    S-T New Member
    15
    Cheers shark_90
    Click on to this yesterday and registered it, (I suppose it will be of more use :) )
  8. S-T
    S-T New Member
    15
    Shark90
    Do I still have to do these if I am only fitting Cruise ?
    Go to module 16 - Steering Wheel
    Recode
    Change the second to last digit (i.e. 0xxNx - where N is the bit to change, x are your current values). If you do not currently have CC or DIS, this should be '0'.
    Make a note of the current coding!!
    Change N to '4' (i.e. 0xx4x)
    Test
    Click on 'Do it'.
    Go to module 17 - Instruments
    Go into 'Adaption - 10'
    Go to channel 19 and click on 'Read'
    Make a note of the 'Stored Value'.
    Change value to x10xxx where x is the same as it was.
    Test
    Click on 'Do It'
  9. S-T
    S-T New Member
    15
    Right sussed it, you dont need to do module 17 - Instruments if your only installing cruise
    Works a treat
    Thanks muchly shark90, more than I originally thought but well worth the extra bit of hassle.
  10. shark_90
    shark_90 Member
    96
    No problem, glad you got it sussed. Sorry I didn't answer your question promptly, I've been working away without internet access.
    The part about 17 - Instruments is to activate DIS, if you have fitted it, so in your case it was not needed.
    All the best
