vag codes help
domg Mar 22, 2010
  1. domg
    domg New Member
    12
    hello i got my car read as the emissions light came on and the iddle has started to hunt between 850 and 875 say the rev counter only just moves a little bit when sat at idle
    these were the codes
    Monday,22,March,2010,19:24:46:56769
    VCDS Version: Release 908.1
    Address 01: Engine Labels: Redir Fail!
    Control Module Part Number: 06F 906 056 CP HW: Hardware No
    Component and/or Version: MED9.5.10 00 5627
    Software Coding: 0000072
    Work Shop Code: WSC 06435 000 00000
    Additional Info: 06F907807A NOX 0306130046 004 3608
    Additional Info: Geraet 00000
    3 Faults Found:
    16544 - Oxygen (Lambda) Sensor B2 S2: No Activity
    P0160 - 004 - No Signal/Communication - MIL ON
    16543 - Oxygen (Lambda) Sensor B2 S2: Response too Slow
    P0159 - 004 - No Signal/Communication - MIL ON
    17439 - Intake Manifold Tuning Valve (N136): Setpoint Not Reached
    P1031 - 004 - No Signal/Communication - Intermittent
    Readiness: 0100 0001
    help as i have no idea what they mean
    i have tried a new lambda sensor and has not worked
    thanks
    [​IMG] [​IMG]
  2. bearthebruce
    bearthebruce Ross-Tech, LLC
    343
    21
  3. domg
    domg New Member
    12
    hi
    thanks for your help i have asked the person that changed it and he has said that it is quite hard to see the rest of the wires as they go up the back of the bulk head but the bits that were were the conector block is looked ok I guess i need to find someone that can check the wires for me then
  4. domg
    domg New Member
    12
    o and thanks for your reply
  5. Fox
    Fox Member
    39
    Try unplugging the MAF, clearing the codes and going for a drive. Then do a scan and see what the results are.
  6. bearthebruce
    343
    21
    help me understand your logic here Fox. The lambda sensor is clearly not working. Why would you recommend unplugging the MAF? Do you think that is going to solve the problem with the Intake Manifold Tuning Valve? Surely you do not think unplugging the MAF is going to have an effect on the failure of the Lambda sensor?
    I am assuming that after the Lambda sensor was replaced, the codes were cleared and then came right back - am I correct domg?
  7. domg
    domg New Member
    12
    yes bear it did i changed it and then in about 20 miles of driving it come straight back on again
    i was a bit confused with the maf thing
    thanks for the help i am just a bit lost what to do
  8. bearthebruce
    343
    21
    I still think the issue is either with the wiring to the sensor or the sensor is seeing oxygen it should not see. Seeing too much O2 could come from a Vacuum leak or from an intake leak after the MAF, or from a leak in the exhaust. Still, the fault codes lead me more towards and intermittent connection problem. But ..... without seeing the car and so on, it's really hard to make recommendations.
    I guess my point is this: you've done the obvious, now you need to dig into the less obvious. The questions to be answered are:
    What's in common with the lambda sensor?
    What would cause the Lambda sensor to report a slow response?
    Don't know if this will help but here is a generic test procedure for testing Lambda/O2 sensors: http://www.autodiagnos.com/fileadmi...bulletins/misc/gea_testing_lambda_sensors.pdf
  9. domg
    domg New Member
    12
    thank you very much for the help where are you based as could always bring the car to you
  10. bearthebruce
    343
    21
    Located outside of Philadelphia in the US. I suspect it would be a long drive using a pretty good snorkel! lol
  11. domg
    domg New Member
    12
    ha ha and i think there would also be a little water damage for you to look at ha ha
    will have to find some one iver here with as much knowledge
    thanks for your help it has made things a lot clearer
