vag codes for an a2
1wheelonly Dec 22, 2008
  1. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,385
    111
    hi
    has anyone got any adaption codes for a a2, a friend has bought an a2 and want to activate beeps on alarm etc.
    got full vagcom but could do with some advise. cheers
  2. VRStu
    VRStu Just Looking VCDS Map User
    1,073
    46 and coding. Not done one before but might pop up in a helper box. If not have a look at the label file.
  3. 1wheelonly
    2,385
    111
    cheers stu
    had a look earlier before the post and no pop up helper box,what do you mean by label file.
    sorry if i sound dumb,still newbie with vagcom.
    thanks again for that test by the way, got it sorted now, it was a leak.
    cheers mate
  4. VRStu
    1,073
    If you look in the root ross tech folder you'll find a folder called labels. using the part number of the controller you are looking at you can normally find the txt file which is the lable file Vag-Com will use to help with the coding.
