Vacuum leak
chipuk Jan 2, 2018
  1. chipuk
    chipuk New Member
    hi all new to this forum
    i have a 97 A3 8l 20v 1.8 non turbo engine
    car was lumpy so suspected an air leak
    i found this part number
    06A103474
    vent hose
    the hoses were split in a couple of places so need to replace them
    anybody know where i can source one in the uk?
    sadly whilst looking for any more leaks
    the breather line broke
    part number
    06A103213 which looks like it takes gases from the crank case back to an inlet on the air intake from air filter.
    do i need to take the oil filter bracket off to fix this or is there another way of doing it?
    i havent checked for codes but have generic cable on order so i should be able to test it later in the week
    diagram i am using is below
    part 2 and 5
    thanks for your help
  2. Tj 0785
    Tj 0785 Well-Known Member VCDS Map User Bronze Supporter Audi S3
    1,672
    355
    Tps ( trade part specialist) probably best place no you shouldn’t have to remove oil filter it can be tricky pulling the old one out mine come out in pieces just be careful you don’t drop any thing down there
  3. chipuk
    chipuk New Member
    Thanks TJ ill have a look
  4. Stuart B
    Stuart B Well-Known Member
    2,052
    375
    the standard connectors appear to be some form of bakerlite compound which crumbles to pieces.
  5. tcg
    tcg Active Member
    586
    222
    43
    Just be careful when fitting the new 'bakerlite' pipe into the oil filter housing...
    http://www.audi-sport.net/xf/thread...ad-my-baby-is-home.261997/page-6#post-2923904
    On my S3,I found it easier to remove the dipstick & holder along with the bracket in front of the inlet manifold(not sure if it's the same for an A3).I just cut the finger off a rubber glove to protect the hole.
    I got the pipes I needed off ebay.
  6. Stuart B
    2,052
    375
    yeah I didn't have as much of the pipe Audi made when I removed mine - lord only knows where that's gone.
    probably why someone found a lucky penny in their sump :)
  7. chipuk
    chipuk New Member
    thanks for the link in the thread makes it much easier when its a bit clean mine is filthy - i did take the front bracket off supporting the dipstick but i moved it a little bit so i could get my sausage fingers in to see and snapped the dipstick pipe with it, it does seem if i move something - something else breaks, still its a good car.
    Stuart B likes this.
  8. chipuk
    chipuk New Member
    is there a good service manual (not the Haynes one i found it rubbish) that anyone has found on fleabay?
  9. Stuart B
    2,052
    375
    I'm not sure the Haynes covers the S3 does it?
  10. hydro s3
    hydro s3 S3 amk Team Ming Blue Audi S3
    461
    89
    No Haynes don't do a manual for the s3. Only do one for the a3 of the same year.
  11. Stuart B
    2,052
    375
    oh hang on the thread opener only has a 1.8 non turbo - sorry :)
    I have a normal Haynes but to be fair youtube and forums are usually best for details.
