Vacuum hose to fuel regualtor
BOOST LEAK May 7, 2013
  1. BOOST LEAK
    BOOST LEAK New Member
    9
    hi all, the fuel regualtor vacuum pipe has fared and spilt on my S3, does any one know the correct size in mm I need ? Is it 3mm/3.5mm/4mm ? I've tryed 2 measure it but can not be sure, I've seen some silicone pipe on eBay but id like to buy the right size. Thank all.
  2. basil brush
    basil brush Active Member
    527
    170
    43
    i used 4mm and works a treat :)
    buy extra and do the DV vacuum line while your there .
    baz
  3. <tuffty/>
    21,786
    4,170
    3mm on the FPR
  4. JUS3IN
    JUS3IN 14.0 @ 98mph 2s 60ft
    1,159
    102
    do all the small stuff under the mani too if you aint already, all that ****e braided stuff mine fell to bits when i took it off!
  5. BOOST LEAK
    9
    HI m8 thanks for replay, is the braided stuff under the manifold 3mm aswell ? Thanks.
