v6 timing belt change
bigdavie Nov 17, 2007
  1. bigdavie
    bigdavie please speak slowly so i'll understand !
    160
    got my timing belt kit today but pretty unwell ( manflu) so i'll be changing it next week .
    it's a 2.4 v6 btw ! anyway i'm gonna take some pics and may write up a how 2 on it !
    but only if there would be some interest
    what do you think ?
    cheers
  2. maxlbrown
    maxlbrown Deep Blue
    248
    are you going to change the water pump and tensioner pulley at the same time.
    By all accounts the water pump is a 5 minute job when doing the cam belt and also the pulley both are common failures if not replaced at the same time.
    to do the cam belt the whole front is supposed to come off to doit let us know how you get on as mine is due soon.
    Good luck M
  3. bigdavie
    160
    got a full gates kit here ! and yeah everything will be changed ! except the water pump ! gonna inspect it once the belts off ! any play whatsoever and yup its off !
    its a very impressive kit i must say !
    i'm a time served mechanic and i have never seen such a wide belt in all my days as a spanner monkey !
    that and the quality of the idler and tensioner ! wow !
    it's a quality car i seem to have acquired !
  4. enda1
    enda1 Member
    436
    The problem with the water pumps is that the impeller is made of plastic. you need to take it out and inspect it for cracks etc. even if there are no cracks visible it might still be close to failure point. For peace of mind it might be better to change it
  5. maxlbrown
    maxlbrown Deep Blue
    248
    Enda is correct the same problem exists with BMW. for peace of mind and £25 I would recomend replacing it. as every thing has to come out to replace it and i think the cam belt has to come off as well so why do the same job twice.
    Regards
    M
  6. bigdavie
    160
    hmm i didnt know they were plastic ! i think i'll just change it then to be on the safe side !
    cheers guys
