V6 Startings Issues after belt change.....
S4_dan Nov 9, 2013
  1. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,762
    167
    Hi I had the belts change on my V6 last monday by a local Garage. They have worked on Audi's before and regularly do belts on Police Audi vehicles.
    Anyway, picked the car up Monday evening and all was fine. Tuesday morning the wife went to start it and she took a few turns before firing which it has never done since me owning it. Tues Lunch it was the same she said. I drove it Tuesday evening and it was fine every time I started it.
    Wednesday it started fine first thing in cold/frosty temps but at lunchtime & evenings it takes a wee while cranking before firing. And same goes for Thurs and Friday.
    I initially thought it may be air in the fuel lines if they had disturbed the fuel system somehow. I know they depleted my Aircon system and re-gassed after changing the belts.
    I only have VCDS Lite (Activated) with an eBay lead so I can't get the TDI-Graph function. And the numbers are all gobble-de-gook to me!
    Any pointers please?
    I've not looked under the bonnet as yet, but have had VCDS scan and nothing shows up for DTC's.
    Dan
  2. S4_dan
    2,762
    167
    Oh, the wife also said that on THursday lunchtime, the engine ran rough for a very short time after starting with black smoke from the exhausts. It has never smoked a lot this car which surprises me to be honest.
    However, the car is due a service in 300 miles so I will do that next weekend.
  3. adamss24
    adamss24 Well-Known Member
    4,584
    408
    Yes,the garage of your choice used the "mark and pray" method so either the crank/cam timing is wrong or the pump is either too retarded or too advanced hence it takes a while to start then the electronics take over...Could also be a battery on it's last legs but it would not account for smoke and rattles...
  4. S4_dan
    2,762
    167
    Even if the the starting is random? Sometimes fires first times straight away, other not so quickly. The smoke has only happened once. The car is used 4 or 5 times a day. Performance hasn't changed (or at least feels like it hasn't)
    I have thought about the battery being weak, will get a drop test done on it for peace of mind.
    Why do you have to live so far away Chris!!! lol
  5. quattrojames
    14,068
    585
    Does sound like fuel pump timing, the irregularity is probably down to other factors such as temperature etc.
    The fact it has only been like it since the belt change is the telling point really.
  6. S4_dan
    2,762
    167
    Is there anyway of adjusting it without TDI-Graph?
  7. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Not really, its pretty precise.
