Using water
ROBA3T Aug 27, 2013
  1. ROBA3T
    ROBA3T New Member
    12
    Hey all
    Just noticed my a3 uses water need to top it up every 2 weeks as it drops below min
    I asked the father in law who I bought it off
    And he said it's done that ever since he had it which he owned for 2 years+
    He had it in a vag specialist and they could not find anything
    I am assuming headgasket? The oil is ok and not getting water in
    Is they any common areas to look at so far I have checked oil
    All hoses and radiator.
    They is no leaks on the drive
  2. towcestervag
    towcestervag Member VCDS Map User
    165
    what engine?
  3. <tuffty/>
    21,885
    4,204
    Are you using water or do you have proper coolant in there? if using the correct G12 variant then it will be obvious if there is a leaking pipe somewhere... G12 leaves nice pink stains...
  4. ROBA3T
    ROBA3T New Member
    12
    Sorry it's a 1.8t 2000model I am not 100% sure if they is coolant in just looks normal dirty water could I not put a dye in the water so I don't waste coolant
  5. <tuffty/>
    21,885
    4,204
    Should be using a proper G12 coolant really dude.. you want to go to a local garage for a hydrocarbons test... that should determine if the headgasket has gone... fairly rare tbh as they are quite sturdy but cracked heads are fairly common...
