Using Water/Coolant
tominski Jul 30, 2007
  1. tominski
    tominski Member
    35
    My car is using coolant a bit quick... having to top up every couple of weeks.
    No signs of water and oil mixing.
    Can it be anything else or is my head getting ready to give up??
  2. batwad
    batwad Member
    864
    Have you checked for leaks? After getting it warmed up, try parking the car overnight over newspaper. You should be able to see any leaky spots as blots on the paper the next morning.
  3. rodenal
    rodenal Active Member
    1,992
    Yeah, in particular check your radiator its pretty easy for it to develop a small leak/have a small hole
  4. marms
    marms Member
    833
    It's a really common problem for the seal on the cap of the expansion tank to leak. This only happens under pressure and often there are no obvious signs of leaking. Really cheap fix by simply replacing the cap.
    Of course it might not be this but it is a very common problem on the Mk4 Golfs and therefore I would imaging your S3 may be prone to the same.
  5. jojo
    28,885
    3,537
    Waterpump is another place where coolant will leak out, but very hard to see, as it's where the cambelt is.
