using to much petrol ???
welchy29 Mar 20, 2011
  1. welchy29
    welchy29 New Member
    22
    hi there, a few month ago i had to change the MAF censor (air flow). but me being a tight bugger and wanting 1 there and then i went to my local scrappy n got a used 1.. problem i had is that i had to match it up to my old 1 cos the guy gave me a big bin n said help ya sen so i did..i dint find 1 with the right code so got 1 that looked simaler (think its of a passat
    anyway the bottom line is that since i fitted it ive been using a hell of a lot petrol..the car is stranded apart from a forge splitter diverter valve also air filter a bit mucky lol..... for example if the computer says 100 mile in tank 10 mins of normal driving then it might av gone down to lets say 80 mile even tho av not covered that millage also the needle will drop too.........been told that a wrong maf censor can cause this..is this true or is it something else.....PLEASE HELP :sos::sos::sos::sos: the car is a A4 1.8T AUTO avant 2000 plate...
  2. Oranoco
    Oranoco Well-Known Member
    3,972
    405
    Sounds like a case of buying cheap, buying twice. Get your wallet out and get the right one for your vehicle and give yourself a slap for trying to be tight.
    A dirty MAF can have a dramatic effect on fuel use. Since cleaning mine I'm getting an extra 50 to 70 miles out of my tank.
  3. welchy29
    welchy29 New Member
    22
    thanx pal..so its deffo the maf censor ?????? newt else
  4. Broken Byzan
    13,237
    465
    0280 217117 is the correct part IIRC.
  5. welchy29
    welchy29 New Member
    22
    ey up pal..part no. on me original maf is 0280 218 063 made by BOSCH
  6. Broken Byzan
    13,237
    465
    What engine code is fitted to her?
  7. nwmlarge
    nwmlarge flat out
    219
    whats the water and oil temp like ?
    mine used so much more when the stat was up the creek.
  8. AndyMac
    9,832
    46
    Just unplug the MAF and see if you get better MPG
  9. welchy29
    welchy29 New Member
    22
    there both fine pal.....
  10. welchy29
    welchy29 New Member
    22
    sorry for sounding dumb but were will i find the code....thanx
  11. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,722
    162
    Inside cover of the manual that came with the car or on the sticker in spare tyre well wall.
