Use of front and rear fog lights
h5djr Sep 23, 2005
  1. h5djr
    9,072
    1,495
    Following on from some earlier posts about the use of front and rear fog lights, I have found the following information in the The Road Vehicles Lighting Regulations 1989 which I assume is still current.
    No person shall use, or cause or permit to be used, on a road any vehicle on which any lamp, hazard warning signal device or warning beacon of a type specified in an item in column 2 of the Table below is used in a manner specified in that item in column 3. Column 2 refers to the type of light and column 3 to the use..
    (2)Front fog lamp (3) (a) Used so as to cause undue dazzle or discomfort to other persons using the road.(b) Used so as to be lit at any time other than in conditions of seriously reduced visibility.(c) Used so as to be lit when a vehicle is parked.
    (2)Rear fog lamp (3) (a) Used so as to cause undue dazzle or discomfort to the driver of a following vehicle.
    (b) Used so as to be lit at any time other than in conditions of seriously reduced visibility.(c) Save in the case of an emergency vehicle, used so as to be lit when a vehicle is parked.
    Wrongfull use is subject to a fixed penalty fine.
  2. necroeire
    necroeire Active Member
    1,008
    I was behind a car the other evening, it was dark they had a new Focus with the rear fog on and it was blinding me. So like any other road user I flashed them and they slammed on their brakes.
    It's a shame there is no standard flash sequence to tell people in front to turn off their fogs.
    If everyone knew that two flashes meant "Turn Off Your F'n Fog Lights" then there would be no issue.
  3. Japper
    Japper Ibis S3 Fan Club
    1,495
    [ QUOTE ]
    [/ QUOTE ]
    That is the standard, it's just that more and more drivers are stupid /ubbthreads/images/graemlins/burningmad.gif
    On the very odd occasion I have been flashed, the first thing you do is check your indicators or lights or fogs.
  4. h5djr
    9,072
    1,495
    One of the nice things with all the Audi/VW range is that whenever you stop and turn off your lights any fog lights that are on are automatically switched off and if you want to use them again you have to make a point of switching them on. It a shame more manufacturers don't use a similar system.
    I'm sure that in some cases drivers switch them on a the first wiff of mist in Autumn and they are then left on all Winter.
  5. Mark_N
    Mark_N Member
    250
    Jesus it's annoying isn't it...
    Rear ones annoy me even more than fronts though. Don't mind front ones when it's daylight but once it's getting dark fronts blind the **** out of you too.
  6. Calibos
    Calibos Member
    I have to say that I have never been dazzled/blinded by front fogs. I have been dazzled/blinded by xenons though. Even those bluey lights on punto's(whatever type of bulb/reflector they are) are distracting.
    It goes without saying though that rear fogs dazzle/blind just about everyone.
    As for drivers getting more stupid with regard to flashing headlights. Its so true. Even in the space of 10 years its amazing the differance. It used to be that 1 time out of 10 a person wouldn't realise their lights were off after being flashed by you. Nowadays it seems that its the opposite. Only one driver out of every ten that I flash, realise I'm flashing because their lights are off.
    I remember a few years ago, I was flashing this idiot for ages that his lights were off with no response. There were streetlights in the area though. He took a turn onto an unlit street and I was going the same direction. I was sure he would then realise his lights were off, but no. My headlights lighting the road from behind him were obviously enough for him. It was only when I switched my headlights off altogether for a second or two and the street went pitch black, that he realised his own lights were off. Muppet! /ubbthreads/images/graemlins/laugh.gif
    Like Japper says, when I get flashed, the first thing I do is check my lights, if they are on I check all my mirrors to see if I am dragging a pedestrian underneath the car /ubbthreads/images/graemlins/laugh.gif. if its not that I listen out for the squeels of a cat wrapped around my axle, and finally if its not that I keep an eye out for a police checkpoint or speedtrap. /ubbthreads/images/graemlins/laugh.gif
    If its not that, then what the f**k was that moron flashing me for!!?? /ubbthreads/images/graemlins/laugh.gif
  7. Halgernon
    Halgernon New Member
    25
    [ QUOTE ]
    [/ QUOTE ]
    LOL - I know just what you mean.
    Trouble is, so many more people these days are convinced that there is a personal issue when you flash them - they want to rip your head off for daring to raise your lights at them... sigh.
    If I remember correctly, one of the problems is that according to the highway code (or at least the version I used when learning to drive back in the, erm, ah, yes... early 80's) flashing your lights has no official meaning other than to signify your presence to another road user.
    Of course, that could all have changed since I last read the book!
    But like you, I tend to look first for a fault with my car or driving, then for speed traps, etc.
  8. imported_Watson
    imported_Watson Guest
    Fog lights are utterly dementing. With front fogs I don't think it's necessarily that people forget to turn them off or put them on in mist, I just think that they turn them on because "more lights on must be better".
    I've stopped flashing people with fogs on now - cowardice at thinking they'll get out with a crowbar...!
  9. h5djr
    9,072
    1,495
    They probably work on the basis - 'I've paid for them so I'm blooming well going to use them and s?d everyone else'
  10. benw123
    benw123 Moderator
    1,863
    My Sportback is the second car I've owned with Xenon lighting, and I'm still surprised at the number of people who flash me thinking I'm using the main beam. Whilst I'm an enormous fan of Xenon lights - IMO they should be standard fit on every car - perhaps they are just too good.
  11. Eeef
    Eeef Lord of War
    1,607
    [ QUOTE ]
    [/ QUOTE ]
    Personally I think they should be banned for exactly the same reason as you stated. If people are flashing you it's coz they're being dazzled which = dangerous to everyone bar the owner of said xenons.
  12. a4cab18t
    a4cab18t New Member
    9
    worst xenon offenders are the chelsea tractor brigade, especially as everywhere they drive is streetlit so they don't even need them in the first place! /ubbthreads/images/graemlins/mad.gif
