URGENT!!! wiring diagram for APU MAF connectors needed
Geeman Mar 3, 2010
  1. Geeman
    Geeman Low Life
    1,318
    Car's in for work, and the guy needs a wiring diagram for my MAF. 1.8T APU engine, 2000 model (facelift).
    Long story short - I spliced in new wires to replace burnt/melted wires from engine fire. I 'may' have got one in the wrong place.
    Any help appreciated!
    Cheers,
    Giles
  2. aragorn
    18,665
    880
    G70 is the MAF
    Connection [21] joins the same color wires from various other sensors, and then goes to fuse 234, so its a 12v feed to most of the sensors.
  3. Geeman
    Geeman Low Life
    1,318
    Thanks (again) dude, but my MAF has 4 wires going in to it though...
  4. Geeman
    Geeman Low Life
    1,318
    Scrap that... just figured out that the connection at the bottom makes up the 4...!
    Doh!
  5. Geeman
    Geeman Low Life
    1,318
    Dude... what's the 'B1' / 200 part on the right of the MAF with the black wire going to it?
  6. Geeman
    Geeman Low Life
    1,318
    Anyone...?
    And does that diagram show it as actually connected to the green wire going into Pin5...?
  7. aragorn
    18,665
    880
    its the shield for that wire, and is connected to ground.
    Edit: actually i'm going to verify that for you... black isnt normally ground....
  8. Geeman
    Geeman Low Life
    1,318
    Shield....? What does that mean? Is it actually physically connected to that wire?
  9. Geeman
    Geeman Low Life
    1,318
    The reason I ask is that the MAF isn't producing any kind of reading... it's just reading '0' (apparently).
    The only thing we can think of is that when I re-wired (some) the loom, I incorrectly connected the black wire straight onto the green wire. Maybe this isn't correct...?
  10. aragorn
    18,665
    880
    Ok just checked.
    grounds are NORMALLY brown on DIN wiring harnesses but it seems this is an exception, and it IS an earth.
    Its a shield or a screen for that wire which basically means instead of it just being a cable with some plastic insulation wrapped round, theres another sleeve of wire around the internal insulation, which is connected to earth, like this:
    http://www.summitsource.com/images/products/MSQ100.jpg
    Thats not quite the same, but it highlights what i mean, the signal wire is the inner core (copper in that picture), then theres some insulation, then the shield (silver braid in that picture) then the outer insulation.
    If you've connected black to green your earthing out the green wire, the black "sleeve" should just stop.
  11. Geeman
    Geeman Low Life
    1,318
    So the black wire shouldn't be physically connected to the green wire then?
    Right... I'll whip it off then.
    Might have to get a MAF connector from another later car to see how it's all put together...
  12. Geeman
    Geeman Low Life
    1,318
    Right... disconnected the black wire from the green wire... but still showing the same symptoms.
    I'll have to trace it all the way back to the ECU on Sunday I think and do a continuity test on each wire to makre sure they're all still in one piece.
    Grrrrr!
    I WILL get to the bottom of this! lol
  13. aragorn
    18,665
    880
    well at least your on the right track now.
    If the MAF is outputting nothing though, how come there isnt a fault code?
  14. Geeman
    Geeman Low Life
    1,318
    I have no idea...! Electrics are the one thing in a car that baffles me!
  15. Geeman
    Geeman Low Life
    1,318
    So... pins 2 & 4 were in the wrong way round. I had no continuity between connector pin No4 and the ECU or pin No2 to fuse 34. Doh!
    Off for a test run now.
  16. Geeman
    Geeman Low Life
    1,318
    No good still.
    Found violet wire running from N80 valve had snapped further down the loom. So soldered that up and now there's continuity from the N80 valve to the ECU... so that fault has now been rectifed. Yay!
    But now, after disconnecting the ECU, I've got a 18048 code error - Internal Contr.Module (EEPROM) Error
    Uh oh...
  17. aragorn
    18,665
    880
    that doesnt sound very good!
    Does it clear?
    If not i'd check over the loom again very carefully, and make sure you've not overlooked something.
  18. Geeman
    Geeman Low Life
    1,318
    It's cleared now. No fault codes at all. Yippee!
