URGENT - Passenger front window stuck down
DALE_AVANT Sep 29, 2012
  1. DALE_AVANT
    DALE_AVANT Member Audi A4 Audi A3 Audi Avant Owner Group Team Brilliant Black TDi
    620
    21
    Hi all.
    As title, the front paSsenger window on our A3 stuck in the down position this morning.
    With a bit of pulling up on the glass, it will travel about 1/4 of the way up, but then opens again of it's own accord.
    I need to fix this today for obvious reasons, any help appreciated!!
  2. jojo
    28,908
    3,564
    One of your window clips are broke. To close it, you need to have one person pulling on the window upwards, and one person operating the window switch. When it gets stuck, it will roll back down, as it thinks it's trapped something, like your head or arm in the opening. Anyways, when it rolls down, operate the window switch again, and it will stop. Now wiggle the glass a little to free it up and repeat the pull up and press window trick. For the last few inches, you just need to grip the glass with your palms both sides, as you can no longer pull on the top of it. Hopefully, that will get you by for the day.
    Instructions to fix it is in the link below.
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/22915-faulty-s3-electric-window-fix.html
  3. DALE_AVANT
    620
    21
    Superb, thank you jojo.
    Has anyone from ASN ever got their head or arm caught in the window?
    :slapped::haha:
  4. DALE_AVANT
    620
    21
    Fixed as directed above, many thanks, the window is now closed.
    The motor seemed very sluggish in raising the window, maybe this is the issue?
  5. jojo
    28,908
    3,564
    No mate, it's a broken clip. The electric motor is trying to push the window up one side and struggling. It will get burnt out eventually, if you don't fix it!
  6. The Doctor
    The Doctor Well-Known Member
    1,394
    189
    Ha ha, not that I know of, but I do know some people (not on A-S.net) whose heads I would gladly shut in my window given half a chance!!!
  7. Benjiman46
    Benjiman46 R-Tech Terrorist
    551
    24
    Broken clip, common fault I'm afraid
    Mine decided to break after I'd waited for an hour in the paddock at santa pod for a run down the strip... Went to put the window back up, nothing... Had no window to grab hold of to pull it up, so had to quickly take the door card off, then push the window up and finger tighten the screw on the clip to fix it while I went down the strip lmao
    good times :p
  8. DALE_AVANT
    620
    21
    Cheers folks, anyone got a part number for the clip from TPS?
  9. jojo
    28,908
    3,564
    Buy uprated A6 ones which are pink, part number is 4B0837463B, just go to Audi and buy 2, they are 3 quid +vat each or there abouts, order two, and swop both on one side whilst you are at it!
  10. thegoal007
    thegoal007 Another S3 owner....
    805
    26
    yep common problem. Happened to me years ago. I did both windows - didn't want a repeat performance on the other side.
  11. jojo
    28,908
    3,564
    A headsup also on these, don't order from this guy on ebay, they are copies, the genuine one have metal inserts.
    AUDI A3 A6 WINDOW REGULATOR CLIPS FRONT L R 1996 - 2003 | eBay
