Urgent - Offset on 18x8.5J Wheels?
MrJoshua Feb 5, 2009
  1. MrJoshua
    MrJoshua '98 A4 2.4 SE
    104
    Hi
    I'm about to buy some BBS LM Reps in 18x8.5J and I've had conflicting info regarding offset.
    Most people have told me to use ET35, however others have said they might poke too much at the front, and to use ET45 with spacers as necessary.
    Also, 225/40/18, or 225/35/18?
    Can anyone help please? I need this info asap as I need to place the order today!
    P.S. I'm very low on coilovers and currently have 16" Audi Sport wheels with 215/55/16 tyres.
    Josh
  2. aragorn
    18,665
    880
    you will never fit 8.5" rims on the car at ET45 imo, it will clash with the suspension, especially on the rear if its a quattro.
    IMO 8.5J is too wide for a standard bodied A4, The RS4 uses 8.5J wheels with ET20, but obviously has huge arches and lots more room. The problem with a standard bodied car, is that if you keep the offset at stock ET45, the wider wheels will hit the suspension, and if you lower it enough to clear, then the wheels will be sticking out the arches.
    If you want to squeeze them on though, then go with ET35 and see how that fairs, you may still need spacers to make it clear the suspension.
  3. Broken Byzan
    13,244
    468
    Some of it depends on FWD or Quattro, i would play safe and do 35 and space accordingly i think, you could get it mm perfect then. Especially with 8.5 inch rims. I have 8inch rims with 225/40 s on @ et35 and they are perfect for my drop etc
  4. MrJoshua
    104
    Damn it... They just offered me a set of 19x8.5 ET45 with 235/35/19 for a very good price and I snapped it up, so it looks like I'm going to have to get some spacers too.
    I've seen lots of photos of 8.5" rims on B5's, so I'd like to think they should fit without too much drama.
    Mine is FWD by the way.
  5. MrJoshua
    104
  6. Broken Byzan
    13,244
    468
    Wicked, it was more a suspension fouling issue you would have had, if you had a quattro, but as you are FWD, you are good to go with maybe a 5mm spacer or similar
  7. aragorn
    18,665
    880
    yep, there must be more room on the front than i thaught.
    Quattros are VERY tight on the rear, but i guess with the FWD you'll have more room.
  8. Siena
    Siena Active Member
    2,626
    I wouldn't go larger than an 18" wheel on a B5 personally, quattro or FWD.
    The ride's going to be as harsh as hell.
  9. MrJoshua
    104
    I don't drive it very often, so I'm not all that bothered about ride quality.
    Having had coilovers for as long as I remember, I'm kinda used to it.
    And the stereo masks the creaks and knocks well enough ;)
    It was a big toss up between 18's and 19's, but when the company I'd ordered through said they opened the box for the 18's and found they were black ones, they offered me the 19's at the same price :)
    I couldn't resist!
    Thanks guys! I'll post some photos when I've got them fitted.
  10. stapo69
    stapo69 All hail the mighty quattro!
    969
    May need a spot of arch rolling on the front, I caught the odd time on the outer edge of the tire when running 8x19 with 235/35/19s. I now run 9x19s, et40 with 5mm spacers so now et35, with a 225/35/19 tires, all be it a little stretched. And I'm pretty damn low but have no issues at all now.
  11. hiltoa
    hiltoa VAG erfahren
    298
    I have to say, that looks absolutely spot ******* on! :hubbahubba:
  12. MrJoshua
    104
    I was going to get 225/35/19 but they were quite a bit more money for the same standard of tyre, so I stuck with 235's.
    Do you think I should get some spacers ready just in case? If so, what size do you recommend front and rear?
    This is my car at the moment:
  13. stapo69
    969
    Well 10mm would bring you up to et35, but you may not need as much being a fwd. I'd wait and see when the wheels come what the clearance is like 1st and take it from there. Can layer up some cardboard or something as a make shift spacer then measure the width of those.
  14. andybnwc
    andybnwc Member
    752
    What size are those tires, they look massive
  15. andybnwc
    andybnwc Member
    752
    also i ran 235/35/19 with a large drop , front arches needed a quick roll back was no problem at all .
  16. dieselfitter251
    dieselfitter251 Blow ma own trumpet?
    1,120
    That is possibley the best ever looking B5 Avants I've ever seen...
    apart from this....
  17. MrJoshua
    104
    Hah, yeah... That's what standard 16's get on them...
    205/55/16
    Balloons
    :sadlike:
  18. Siena
    Siena Active Member
    2,626
    Believe me, it'll bother you before long.
    With 19" x 8,5" wheels, you'll become a "cautious" driver - any road imperfection (including the ones not really visible) will become a threat. With the ET level, B5 weight and suspension height, the inner wheels are easy to buckle.
    Sure they look good, but take a look on www.rs246.com and hear different views. Some of the RS4 boys stick to 8,5 " x 19", but say the ride is awful, there are lots of buckled rims in the classifieds section too. Most reverted to 8,5" or 9" x 18" after severe tramlining issues.
    And bear in mind, these cars are widebody, so if they're having issues, imagine what it'll be like on the slim-shouldered, slim-hipped regular B5.
  19. aragorn
    18,665
    880
    That black RS4 looks ****** awesome, although it needs joey modded lights and no red ring to complete the look, imo!
    When we finally get round to replacing the car, i want a black avant quattro, and although the RS4 body's likely out of reach, the rest of it should be possible!
  20. prodrive
    prodrive New Member
    29
    225/40/18 tires and ET32 to 35 offset would be ideal for your car ....
  21. docurley
    4,073
    88
    That black RS4 is in fact a S4 with RS4 body parts.
  22. MrJoshua
    104
    As I said, with my last 3 cars having coilovers very-very low, I know all about being that cautious driver :)
    I'll have to see how I get on... I've ordered a set of 5mm and 10mm spacers which will make ET35 on the back and ET40 on the front).
    If all else fails, because they're ET45, I should be able to sell them to the MK5 Golf crowd.
    Thanks for the advice... I'm going to suck-it-and-see!
  23. MrJoshua
    104
    I found this photo which shows just how ridiculous mine's going to look with 19's :)
    Awesome :jester:
  24. stapo69
    969
    ^^^^^That looks sweet,^^^^^ some skinny stretched tyres on that bad boy, and possibly airride looking at that stance, but v nice.
    Good luck getting them on, and get the pics up sharpish! LMs rock.
  25. MrJoshua
    104
    Yeah, there's not much rubber on that one is there!
    They're being delivered on Wednesday (I'm working from home!), so assuming the spacers arrive on time, I should have some pics on Wednesday evening! All being well!
    Thanks!
  26. Markey
    Markey Active Member
    2,175
    Nice looking forward to them its going to look sweet :)
  27. EddyH
    EddyH Member
    67
    Looking forward to seeing them on the car Josh. It's looking good in the photos even on the 16's.
  28. jcb
    jcb Active Member
    4,132
    13
    you can get away with a lot on coilovers.
    I had standard 18"x8J ET43, 225/40, then with 10mm spacers all round. both cleared fine with the height wound down to give about 3/4-1" clearnace between tyre and arch when viewed from side (at its lowest, usually a little higher)
    Now run 18"x8.5J ET24 with 245 Goodyear eagles F1's,
    Arches are rolled but not pulled, front clears without any issue at all, even when viewed from above there is a slight overhang.
    Front
    Rears look worse but as the coilovers are pretty hard they have only caught the arch twice in 6 months, once with 5 people on board and once when I forgot about the boot full of tools I was carrying when over a speedbump.
    Back
    it is only temporary until my arches are widened about 1/2-3/4"
  29. PaulJC84
    PaulJC84 Owner
    2,922
    17
    How much clearance is there on the inside with those 8.5" wide wheels JCB?
  30. jcb
    jcb Active Member
    4,132
    13
    more than there was on the ET43 8J rims to be honest.
    They are 19mm further outboard than they were before and the tyres are only 20mm wider.
    if I had the choice I would tkae 8" every time.
    These are a constant pain as they not only tramline a lot more but I find myself having to play around with suspension set up and tyre pressures all over again to get it where I want it to be.
    understeered like a bitch when I first had them done. bit better now but I am running 5psi less up front and a couple of clicks harder on the rear compression settings.
    glad I don't have ARB's!
  31. aragorn
    18,665
    880
    Did you remove them?
    I'd imagine that leaving the front ARB alone (ie standard), and stiffening the rear a little, would help out the understeer.
  32. PaulJC84
    PaulJC84 Owner
    2,922
    17
    Cool so 8.5" with say an offset of 35 would have sat nicer than the ET24 you have.
  33. jcb
    jcb Active Member
    4,132
    13
    I think they would catch the brake calipers. 8"x18" ET24 would be what I would call perfect.
    aragorn
    By "no ARB's" I meant that I had not altered them, a set of uprated front and rear would just make it worse.
    I am playing with tyre pressures and rear damping/rebound to dial it out at the moment.
  34. MrJoshua
    104
    Only 2 days till mine arrive!
    Just to clarify, mine are 19x8.5J ET45 with 5mm spacers up front (so ET40) and 10mm spacers up back (so ET35).
    235/35/19.
    Thanks for the photos... I think mine >SHOULD< be OK... We'll see!
  35. MrJoshua
    104
    Who else has ever attempted to roll their own arches with a claw hammer, in the rain?
    They fit like a glove with the spacers I bought. Shame I'm a teeny bit too low! SCRAAAAAAAAAPE
    Aragorn was right - The fronts do foul the suspension arms at ET45, but I found this out when fitting the first one, so I just stuck the 5mm spacers on the front and the 10mm's on the back (no clearance issues, just to get the stance right).
    So, I need my arches sorting... Probably pulling out a bit at this height.
    Know anywhere in Sheffield that's cheap?
    Photos when it stops hammering it down with rain!! :)
  36. MrJoshua
    104
    Photos (from my iPhone... I didn't want to get the DLSR wet!):
  37. aragorn
    18,665
    880
    Looking good.
    Have you damaged the paint on the nearside front wing? or is it just a reflection?
    I think the rear could do with a little less spacing to tuck the wheels in a little more, but thats personal preference, i like the rim to be inside the arch a little.
  38. MrJoshua
    104
    Thanks!
    Yep, my DIY arch rolling skills need some improvement.
    This is my "beater" car - It cost me a grand almost 2 years ago, so I'm not overly concerned about a bit of paint... I've got a touch-up pen :)
    The wheels will go on the B5 S4 I'm thinking about buying next!
    I'm happy with the stance... Just need my Dremel to charge so I can cut out some more of the front arch liners.
    I really should leave this to people who know what they're doing, but where's the fun/frustration with that?
    Edit: Just to clarify so I don't offend: It's not the type of car I'm referring to as being a beater, it's this car that I bought from the back of the paper as a stopgap between cars... It was meant to last 3 months, but I liked it so much I decided to keep it until something catastrophic goes wrong with it!
  39. MrJoshua
    104
    I just looked down the rear arch from above, and you can't see any wheel or tyre poke... Just arch and floor :)
  40. aragorn
    18,665
    880
    Ye they're certainly not sticking out too much.
    Our cars had a dented front wing with a similar amount of cracked paint since we baught it, and surprisingly its not actually rusted bar some brown discoloration in the year we've had it.
    I managed to get another wing from a chap on here breaking a car though, so when i get some free time i'll swap that on and it should be good!
