URGENT HELP with my Blown Turbo!
kaz219 May 5, 2009
  1. kaz219
    kaz219 Active Member VCDS Map User
    1,808
    Hi guys.
    Sorry for the lengthy post but hope someone can shed light on my situation..
    I know my turbos blown but the RAC guy came down today to tow my car to the garage however, it wouldnt turnover (i thought the batt was dead as its been parked up for over a month). I told him to give it a quick check.
    Checked the battery (it was flat so we jumped started it) and it wouldnt turnover.
    He said my engines seized as the oil was very low (about a 1/4) and it wasnt enough so it seized - it had 3/4 in it around 2 weeks before the turbo blew - this lead me to believe that the turbo seals had gone and pumped the oil out.
    But, i took the pipe under the Intake Manifold Flap out (which goes to the turbo) and it DOES turns over, just doesnt start as the pipe leading to the turbo isnt connected and the batterys dead (its on charge now).
    So, am i right in thinking:
    1) The turbo has seized which means the engine air/gasses cant get air out (Like a potato the exhaust as a member said before).
    2) The engine is not seized as it turns over?
    its just not starting but thats becuase the battterys low but I'll turn it over in a few hours when the batterys charged. It turns over for a few secs and then died as the battery went flat.
    and
    3) Am i ok to start my engine without the turbo connected? Just for a few secs to make sure the engine runs fine etc.
    Any other opnions/help would really be appreciated.
  2. Lex
    Lex Member
    365
    :scared2:That sounds like bad news man
    i cant help becuase i replaced my turbo just before it was about to go.
    hope you get it sorted man
    and don't stay up to late like usual
  3. VWAddict
    VWAddict Member VCDS Map User
    656
    9
    I didn't think that the exhaust turbine simply not turning can completely "block" the exhaust gas path. -Slow it down, certainly, but NOT 'bung' it... -Someone please tell me if I'm wrong.
    Measure the voltage at the battery terminals. If a cell in the battery has actually died, then no amount of charging will get you to 12 volts...
    I've heard of lots of 2.0 Diesel engines over there failing, but it's usually not the turbo... most of the "doom" reports I've heard have been about the heads breaking, (unless I dreamed all of that up!).
    Keith
  4. kaz219
    1,808
    According to Khufu on this thread: http://www.audi-sport.net/vb/showthread.php?t=71293
    The car in that thread has the same symptons as mine and on his, it was the turbo...i really need to pull my turbo off myself to take a look but got bloody exams till the 20th and my A3s been parked up for 2 weeks with a blown turbo and 2 weeks when i was on holiday!
  5. kaz219
    1,808
    Update: just connected up the charged battery and it turns over :D :D :D
    Engines defo not seized!!! (MA) Stupid RAC guy gave me a bloody heartattack!
    Am i ok to start it without the turbo attached to the car or will it even start? Just for around 10-20 secs so i can make sure they're no funny noises as there was a grinding noise after it blew?
    Khufu was right about the turbo not letting the gasses out!
    Just hope the turbo turns up tommorrow.
  6. mattandrew
    mattandrew Member VCDS Map User
    977
    21
    TBH mate if your not 100% you could end up doing more damage by starting the car. If the turbos disconnected is the oil supply also disconnected??
    How come the RAC didnt take the car to the garage and let them sort it
  7. kaz219
    1,808
    Turbos just diconnect at the IMF so the gases arent going into it. I was worried about the oil too that why i asked. But everything else is still connected.
    RAC did come to take the car to the garage as they had a replacement turbo being delivered tommorrow but the RAC guy said the engine is seized (which its clearly not) so thought Id keep it at home until i could get a new lump rather then it sitting at my mates garage taking up space.
    But going to tow the car down tommorrow and get them to fit the turbo but just wanted to make sure the engine is right before i do as the RAC guy really scared me with the **** he come out with.
    But i dont think i can start it without the turbo on (if anyone knows if you can, do let me know) so I'll just get the new one fitted and start praying that it goes ok.
  8. mattandrew
    977
    21
    sounds like a plan, get it to ur mates gargae and go from there
  9. VWAddict
    656
    9
    ...and then in the same post...
    -See that's what puzzled me at first...
    But then later on you said that you haven't STARTED it with the intake pipe disconnected, but we'll assume for now that the turbo was PREVENTING it from starting...
    It's all a bit confusing for me! If the shaft has indeed seized, then the engine will not run wide-open, but might indeed run, because quite a bit of air can still flow past the vanes even if they don't turn... -It's one of the advantages of a turbine blower over a positive-displacement blower. -It won't run at ALL happily at higher speeds or heavy load, but it would start & idle, I'd have thought... -That being said, I've never tried it.
    In my first reply I was still baffled by the 'seized' thing. -I think the RAC man just wanted to pronounce it dead so that he could get away to the boozer/his girlfriend. :undwech:
  10. kaz219
    1,808
    Hi- i'll try and clear things up.
    The RAC guy came when the car first went wrong (bang, white smoke, power loss etc.) and it wouldnt turn over. so he jumped started off his truck and it still wouldnt turn over - he said the engine had seized due to low oil (we pul oil in and then turned it over but nothing).
    So, i disconected the pipe at the IMF and turned the key and it turned over but it didnt start as the battery was flat/low.
    So i charged the battery last night and turned it over with the key but didnt let it start as the inlet wasnt connected. It did turn over as i heard the engine turn over and the cambelt had moved from its previous position.
    I called the RAC out again for a proper check as the other one lied about the engine being seized - theyre on their way now (should be here for 1.30pm).
    However, my friend (whos an ex mechanic) came around and we connected up the inlet pipe and started it. It started fine, sounded good but we turned it off in around 5/10 secs.
    In this time, the oil went from just under 3/4 to just over a half.
    i think my intial prediction on the turbo blowing its seals and drinking oil was right - its just the RAC guy gave me a fright as he said the engines seized as the oil was too low after the turbo blew. My mechanic friend also thinks the same.
    The reason of the thread was to get opnions on what i thought:
    1) The engines not seized and the turbos blown?
    The turbos not arrived so tommorrow, i will have to pull the turbo unit off and take a look. I hope fitting a new one cures the problem but just called the RAC guy out again to confirm this.
  11. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    IM GUTTED FOR YOU KAZ ...REALLY AM I HOPE YOU SORT IT OUT YOUVE SPENT QUITE A BIT OF DOE ON IT .....
  12. kaz219
    1,808
    Thanks Blazin :(
    But kind of good news - just the turbo sounds to be goosed. The RAC had the engine running today and it still sounded as sweet as a nut - not seized as the other guy said!
    Its drinking oil so im pretty sure the turbo seals have gone and white smoke!
    My batterys dead too so thats also why it didnt start first time round...
  13. 10blazin
    3,301
    oh if its just the turbo then i know it may be up to 500 but at least your engine isnt seized i think id start crying lol if my engine seized..... just by chance the other day i checked my dipstik and it was dry as hell but my warning light didnt come on i wonder why ???? Anyhow kaz hope you gettit sorted without to much trouble pal
  14. kaz219
    1,808
    Thanks mate - hopefully the beast should be back up and ruuning this week
    the diesels drink up to litre per 1k miles (Audi said) but not sure on the petrols but just keep checking it weekly to be on the safe side! your lucky the engine was ok after having no oil in it!
    My car had a 1/4 oil in it and no warning light either - does the A3 have an low oil warning light?
  15. VWAddict
    656
    9
    Cool. The explanation makes more sense, but that first RAC bloke was definitely way 'off the reservation' with his diagnosis.
    Do diesels blow WHITE smoke when they get oily? -I'd have thought it was blue/brown like a petrol motor? -Usually I associate WHITE smoke with coolant in the combustion chamber, like with a blown head-gasket... (not wanting to worry you further!!!)
    Keith
  16. kaz219
    1,808
    I dont know - usually its white smoke if the turbo blows i was told...(which is what is happening)
    Coolant levels are fine - not dropped at all so im pretty sure the head etc. are ok (even though the A3 TDis' are known for their porous heads!).
  17. Bugsy_27
    Bugsy_27 Vorsprung Durch Technik
    652
    So things are looking up then Kaz? finger crossed it is up and running this week mate!
  18. redbutcher
    redbutcher Member
    649
    Glad things are looking better for you mate. Yes, there should be a low oil warning light - mine certainly has one. You should get the oil symbol appearing in the DIS and the annoying beep everytime the ignition is turned on.
  19. kaz219
    1,808
    Yup - Just waiting for the turbo to arrive an will se how it goes :D
    Cheers mate - when i change the oil, I'll empty it and turn the car on (Not start it) and see if anything pops up.
    Even with just under a quarter of oil, no light. The sensor might be faulty so may have to replace it.
    Blazin - get your oil sensor checked out too!
  20. Khufu
    Khufu Well-Known Member
    5,704
    31
    what do you mean with quarter of oil? Do you mean on the dip stick between min to max? Most cars take about 1 litre from min to max on the dip stick. The warning light will only come on when your off the bottom of the dip stick! It will usually take a litre to get it to show on the dipstick & one more to top it up to max after the warning light has come on.
  21. kaz219
    1,808
    i was refering to when there was a quater on the dipstick.
    My audi takes 3.8 litres of oil.
    So if there's no oil showing on the dipstick, there could still be up to 2.8 litres of oil in the engine ?
  22. Boydie
    Boydie Boycie VCDS Map User
    3,246
    353
    I hope you are putting in a bigger turbo :p
    How do you know if your turbo is "about" to go??
    I am verging on 90k miles with near trouble free engine problems (bar throttle body which was an easy fix)
  23. Khufu
    5,704
    31
    there will be some in the oil filter & around the rest of the engine, but pretty much yes. We get people in the garage/forecourt - oil warning light has just come on. Usually takes 2 litres to top up to max unless they have been driving about for a while wondering what the light was for LOL
  24. 10blazin
    3,301
    maybe my oil wasnt low enough for the sensor to be going off but when i checked the dipstick it was verylow so i just maxed it with oil
  25. kaz219
    1,808
    Unfortunately not - insurance is an absolute bar steward for me and even though i could have had my turbo rebuilt for around 600+VAT, i couldnt jutify paying the extra £400 on the insurance! lol
    Before mine blew, it started whistling alot louder and the high pitched turbo whine got a bit more high pictched but it was a bit out the blue..
  26. phil76
    phil76 Active Member
    572
    40
    Depending on if it is the seals why the turbo has gone,you want to be looking at the blades because if the floating bearing has gone then the blades will have probably wiped themselfs out on the housing sending shrapnel through your oil system,when mine did this on my golf i replaced the feed pipe plus you have got to clean out all the system otherwise might just break new turbo so get intercooler cleaned,all boost pipes,oil change and filter etc because you dont want to be doing it all again next week,plus if there is loads in the exhaust it takes ages to get rid off and burn off so if you can afford it and you havnt got one it may be time,
  27. kaz219
    1,808
    How do i got about cleaning the intercooler ?
    And i was going to clean the hoses out as well as renew the seals/gaskets etc.
    I was going to change the oil/filter and then change it again after a few hundred miles just to make sure there's no debris left.
  28. phil76
    572
    40
    Basically block one end and flush with hose pipe or put in a massive tank or something of the same idea obviously slush water about in there,should harm as long as properly dry before you put back on,and always change oil feed pipe the metal one that should run from oil filter/cooler housing to the turbo because if anything does happen they will always want proof you have renewed but to be honest warranties on turbo's are a very big loop hole in been paid out for
  29. kaz219
    1,808
    I never rely on warrantys, they never pay out but there is a 3 month one with this - Im just praying that it works ia.
    My friends got a spare metal turbo pipe so I'll switch it with that and change the rubber ones over as well as the seals.
    Looks like im going to have to clean the garage out now to get to the pitt :(
    Doesnt sound like a job for axle stands and trolley jacks!
