URGENT!! HELP PLEASE!! :(
MoAudi1.8T Jul 5, 2011
  1. MoAudi1.8T
    MoAudi1.8T Member
    181
    Hi there guys,
    my mates just bought a 2.0 tdi 2004 with 80k. But yesterday it was driving normally and out of nowhere we heard a snap/bang and whitish smoke starting pouring out what appeared to be from the exhaust!!!!
    As we saw this, we stopped the car immediately, but when we went to restart the car it wouldnt start! All engine lights (ignition) comes on as normal but does not start! Tried jump starting but no luck! Have a feeling the battery has had it
    Please someone shed some light on what this could be
  2. gary3306
    gary3306 Active Member VCDS Map User
    989
    41
    Sounds like the timing belt has snapped.
  3. MoAudi1.8T
    MoAudi1.8T Member
    181
    Really? :( . Has he caused any more damage? We stopped the car immediately but iv heard snapped cambelt will bend the valves?
  4. Jiggy
    Jiggy Member
    Could have caused more damaged but I would get it checked out ASAP, dont drive it anywhere even if you do get it start somehow!
  5. daver555
    daver555 Member
    116
    Unfortunately it does indeed sound like a snapped cambelt! DO NOT ATTEMPT TO START THE ENGINE! In doing so you will almost certainly cause further damage to the engine. You may be very lucky and get away with a few bent valves but knowone will know until it's been opened up and inspected. Good luck!
  6. gary3306
    989
    41
    It'll not start, thats for sure. Its gonna be expensive and it WILL have bent a valve(s) and possibly snapped followers too. Sometimes is just as cheap to source a replacement lump
  7. MoAudi1.8T
    MoAudi1.8T Member
    181
    I had a feeling it might have been. When u say he may be luckynto get away with a few bent valves,im assuming this is repairable?
    Thanks for the replies boys
  8. Adam.
    Adam. Meow.
    662
    34
    Sounds like a boost hose has popped off to me....
  9. gary3306
    989
    41
    Yea, just need new valves installing
    It would still start and run
  10. Adam.
    Adam. Meow.
    662
    34
    But if the belt had snapped it would have cut out straight away instead of pumping out white smoke..........
  11. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    Boost hose usually would result in black smoke as the ecu would over fuel as it is loosing air. Given that fact that it won't start it does sound serious, white smoke would usually indicate water involved somewhere.
    Needs expert investigation I'd say.
    Good luck.
    Paul
  12. shady-ninja
    shady-ninja Active Member
    999
    53
    how could you guys mention anything close to the timing belt.
    when the timing belt goes the engine gives no warning no smoke
    no judder, it simply goes off with no drama.
  13. Khufu
    Khufu Well-Known Member
    5,704
    31
    It could be anything, guessing without seeing it is poinless. It could be the turbo, I've read of a seized turbo stopping a car from starting. If it was the timing belt the engine would sound like its turning over quickly but not starting. Could be headgasket & now the bores are filled with water, the list goes on...
  14. gary3306
    989
    41
    Well in my 30+ years in the motor trade, I can quite easily say timing belt. The white smoke would be unburnt diesel!!
  15. amar06fbr
    amar06fbr Vorsprung Durch Technik
    1,055
    68
    that's what append to mine 2 months ago, lucky i got extended warrenty, audi recoverd the car and checked it the following week and come out with the head gasket, glow plugs and turbo, and hopefully should have it back tomrow
  16. NHN
    29,400
    1,738
    Loud bang, pop, whistle etc & then white smoke sounds turbo to me, but given it wont start aswell, urm could be worse, speculative atm from all, drag her **** into garage to have a look.
  17. MoAudi1.8T
    MoAudi1.8T Member
    181
    Sorry i havent been on, been trying to sort out the car!
    As some of you had suggested it was the turbo that went! the old turbo was gone completely! car is running fine now thank God! however the car is smoking slightly but dark black smoke, but only when we kickdown we see thick smoke for a second and then clears up and when driving normally no smoke is seen?
    mechanic says that it is the excess oil that is burning off because apparently the car had lost a lot of oil and since topping up the old oil is still being burnt off? does this sound right
    amar - which extended warranty do you have cos iv been tryna convince my m8 to get one?
  18. gary3306
    989
    41
    Good that you've got it sorted. I went for timing belt because of the 'no start' bit. The oil that you are seeing is most likely oil that is sat in the exhaust and producing clouds as you boot it. I did a turbo on an LDV van a while back and the black smoke was unbelievable. Only way I could resolve it was to bin the exhaust and put a new one on. Have a look at the exhaust tail pipe. Any oil there?
  19. MoAudi1.8T
    MoAudi1.8T Member
    181
    cheers mate :)
    yeh looked at the exhaust tailpipe and doesnt seem to be any oil there :S . when driving casually no smoke is seen whatsoever so thats why were a bit confused aswell
  20. gary3306
    989
    41
    Something to bear in mind. Its a possibility
  21. Khufu
    5,704
    31
    If the turbo was putting oil into the exhaust it can take a while for it to totally clear. Glad its sorted now :thumbsup:
  22. MoAudi1.8T
    MoAudi1.8T Member
    181
    Khufu I think that may be the case. What would you suggest be the quickest way to clear it? long run on the motorway ? or kickdown everywhere :w00t:
  23. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,269
    164
    A lap of the M25 on a day thats its moving will burn off the oil and more importantly it should clear the cat as well if it gets hot enough. :)
    It will clear in time anyway but i know i coked up the cat on my VR6 once and a good blast cleared iot out but its sustained heat that does it.
