urgent help please no third or forth gear
Haglos Jul 3, 2010
  1. Haglos
    Haglos jabba mapped
    247
    i have noticed my car has been getting harder and harder to select gear and now there is no third or forth can anyone shed some light on this please i bet its an expensive fix. :crying:
  2. XFi
    XFi In need of a V8.
    491
    47
    Can you select them easily when the engine isn't on? Could be a linkage issue or a sycro... hopefully just a linkage issue!
  3. Haglos
    Haglos jabba mapped
    247
    i can select them but then the engine just revs and no go
  4. spliffey
    spliffey Member
    78
    mine also does this in first but when car is off its easier to get into gear, any advice? could a clutch needing change be the prob?
  5. Haglos
    Haglos jabba mapped
    247
    it will select first and second ok and drive as normal as i try put it into third it just makes a grinding noise and wont go in the same as with 4th but it selects 5th and 6th ok and drives as normal
  6. Prawn
    11,608
    3,582
    Sounds like a snapped selector fork to me. Common problem on the 6 Spd boxes sadly. The selector snaps and the 3rd-4th gear synchro is stuck on 4th, happened to a mate of mine at the ring at Easter, £500 for a gear ox rebuild with new selector, new 4 th gear and a replaced bearing. Not sure what the labour would be as we removed and refitted it ourselves
  7. Haglos
    Haglos jabba mapped
    247
    cheers prawn what a bugger i better get on the phone now to some specialist would it be cheaper to source a second hand gearbox or just get it rebuilt then i know its done and it wont happen for another 86k miles lol
  8. Broken Byzan
    13,237
    465
    Rebuild, for the reasons you stated above.
  9. aham_uk
    aham_uk Member
    32
  10. Haglos
    Haglos jabba mapped
    247
    i will defo have a go at that work starts tomorrow as i need my car. just a quick question my friend was talking about a corrado g60 gearbox but i said it would not fit am i right and is there any gearbox or stronger gearbox to use 5 or 6 speed
