URGENT HELP needed with rear B6 S4 brake conversion to B5 1.8TQS
B5QUAT Oct 12, 2012
  1. B5QUAT
    B5QUAT Member
    317
    13
    Hi,
    Bit of help needed quickly please!
    Had the front B6 S4 brake conversion done to my car a few months ago and now I'd got all the bits to do the rears I sent them off to the garage today.
    I sent
    300mm rear discs (off B6 S4)
    Facelift B5 S4 rear calipers
    Trig brackets and longer braided brake hoses
    new facelift B5 S4 rear pads
    NOW! BIG PROBLEM........my handbrake cables don't fit.
    Am I right in presuming I need facelift B5 S4 ones or not................PLEASE HELP!!!!!
  2. PaulJC84
    PaulJC84 Owner
    2,912
    17
    I am sure I read that people can make these fit with a bit of adaption on one of the US forums or yeah the S4 cables is another option.
  3. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    they will fit, you may have to strip them down a bit
    they are self regulating on the TQS
    I have RS4 rears on and they required a bit of fettling IIRC
    I forget exactly what it looks like but if you (or your grease monkey) strips the cable off there should be a section that can unscrew (IIRC it screws itself in to keep the cable tight )
    not ideal info but hopefully that helps
  4. Broken Byzan
    13,237
    465
    reset the cable and pull it through about 25mm, job done. It worked well for me any many others
  5. B5QUAT
    B5QUAT Member
    317
    13
    Thanks guys. I'll pass the info on and hopefully get it sorted.
  6. B5QUAT
    B5QUAT Member
    317
    13
    Quick update. New adjustable handbrake cables fitted and all is good. Now have 345mm front and 300mm rears!
    Someone must've fitted cheap and nasty cables previously as they wouldn't adjust properly at all. New ones on were a piece of cake.
    Next for me now......FMIC then GT28RS.....after Christmas!
  7. Wahlstrom
    Wahlstrom Active Member
    410
    145
    43
    Hi...
    Old thread... But where did you adjust the cable?
    Fitted S4 rears to my B6 Tdi Fwd, and I cant get it in to the mechanism.. outer cable as well as the cable it self seems an inch or so too short...
    Please help
  8. Wahlstrom
    410
    145
    43
    Ok.. Just found out that the OEM S4 cable is at 1700mm which means 3 cm shirtene than the ones fitted now...
    What to do??
  9. Bradderz_1988
    3,958
    238
    I had no problems with the handbrake cables as i did the bracket mod as per ecs tunings intructions, are you using B6 S4's or B5 S4's with B6 discs ??
  10. Wahlstrom
    410
    145
    43
    Im using B6/7 calipers..
    What brackets are those??
    Got a picture
  11. Wahlstrom
    410
    145
    43
    S4 cable are the same left and right and both at 1700mm..
    Mine are 1900mm and 2000mm
  12. Bradderz_1988
    3,958
    238
    Try over in the B6 forum you might get a bit more info over that section, i cant see why a 1.9tdi would have longer cables than the S4 ??
