Urgent Help Needed! Where do these wires and this pipe go? AUM 1.8t
Lingo89 Nov 18, 2012
  1. Lingo89
    Lingo89 Member
    114
    Hey guys,
    I'm so close to getting my engine converted 1.6 to AUM 1.8 turbo running properly but I'm having an issue at the moment. I have this one set of wires running from my intercooler up to my engine bay which have been cut and I have no idea where they are supposed to go to wire them back together, I took them out of their black casing and these were the wires within:
    Additionally, behind the coil packs I have this one small pipe which should connect somewhere but we cannot work out where:
    As it is, the car is hard to start (splutters quite a bit as if the timing is off) and then when it does start it doesn't want to be revved, it's very down on power but will idle fine.
    Thanks for any help in advance!
  2. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    77
    Could it be for the map sensor?
    Lingo89 likes this.
  3. Lingo89
    Lingo89 Member
    114
    I'm certain that's what they are, but where do they connect to the coil pack loom?
  4. camscockle20vT
    1,740
    77
    Not to sure dude, check a haynes manual or google is best bet.
  5. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,184
    That bundle of wires IS for the MAP sensor, It's a 4 pin plug with only 3 wires going into it. With the map sensor unplugged you get the symptoms you are having. From that picture it looks like that is the map sensor end and not the part that comes from the loom. The map sensor wires are in the the throttle body electrics bundle.
    I considered doing this, but bottled it due to the fact I'd **** it up - VWVortex.com - DIY - MAP Sensor Connectors / Plug & Play Diode Install
    The pipe looks like the one that's meant to go on the top of the N75.
    Lingo89 likes this.
  6. Lingo89
    Lingo89 Member
    114
  7. 16Klappe
    5,795
    1,184
    Yes the N75 pipe being disconnected will cause huge issues with boost control.
    Lingo89 likes this.
  8. Prawn
    11,532
    3,470
    it it's an AUM it's possible that that little stud is one of the redundant pipes for the N249 or original DV feed.
    How do you have your DV and N75 mplumbed up currently?
    Can you trace that pipe? you may find the other end is disconnected as well.
    Lingo89 likes this.
  9. Lingo89
    Lingo89 Member
    114
    I'm starting to worry about this. Is there anywhere I can check my pipework against pictures of how it should be as standard. I really want to get this all sorted so I can start going nuts with modifications.
  10. superkarl
    superkarl MAN OF STEEL
    9,480
    2,435
    where are you located?
    having someone with good knowledge of these engines have a look for you would REALLY help you out
  11. Lingo89
    Lingo89 Member
    114
    I live just on the out-skirts of East London and Essex. Indeed I could definitely do with some knowledgeable assistance here.
  12. A3 T
    A3 T Lord Of The Rings
    1,067
    15
    Have you got a picture showing it from more of a distance?
    I've got so many pictures of my engine bay that I'm sure ill have one showing where it goes ;)
  13. Lingo89
    Lingo89 Member
    114
    Okay guys, I've managed to get under the car and see where that pipe goes. It connects to the turbo here; where should it go up top?
    I've also located my N75 valve which appears to all be piped up. I can't see how any of it would be wrong as it was piped to the donor engine before it was fitted to my car and the little metal clamps are so tight they seem to still all be connected from OEM. Here is the N75 setup:
  14. Lingo89
    Lingo89 Member
    114
    *BUMP* Does nobody know about the above? :( I've ordered a new MAP sensor which should resolve the issues I'm having that but I can see this one unconnected hose causing serious lack of power issues, especially since it appears to be coming from right by the turbo!
  15. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I think it should go to your actuator,, what turbo is that?
  16. Broken Byzan
    13,237
    465
    Isn't that a left over pipe from the n249 delete that is no longer used on this install. It's sucking air so bung it up assuming its onthat metal TIP
  17. Lingo89
    Lingo89 Member
    114
    The turbo is a K03S. Still think it should go to actuator?
    What n249 delete? the engine bay is currently completely standard. It most certainly won't be when I can get it running right though!
  18. Lingo89
    Lingo89 Member
    114
    Surely, with all the 1.8t tuners on Audisport, someone must know for sure where this pipe goes!? :bye:
  19. A3 T
    1,067
    15
    PM sent mate ;)
