URGENT HELP NEEDED !! center display wont turn off !!
AUDI@WRC Mar 4, 2007
  1. AUDI@WRC
    AUDI@WRC hows my driving call 0800-EAT-****
    84
    i needed help guys my center display stopped working yesterday so i found a post on the forum about resitting the display tried that didnt work BUT now the display wont turn off even without the keys in !! i have removed the screen but it still lights up the small leds behind the display which will run down my battery.
    any ideas how to turn the leds off ?
  2. 205man
    205man Active Member
    1,072
    14
    a hammer?
    alan
  3. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    may be disconnect the battery? just an idea dont blame me if it goes wrong
  4. 205man
    1,072
    14
    cant the display be disconnected from the rear?
    there are 3 connecters on the back one of them must be for the display, and im guessing it would be the centre one as it the nearest to it
    alan
  5. AUDI@WRC
    84
    its the first connection but that is needed to turn everything on as well
    what could go wrong if disconnect the battery ?
  6. AUDI@WRC
    84
    i have pulled the fuse out which turns off the leds but it also turns dash lights and the mileage as well do you think this could cause problems ?
    i am hopefully going to get another instrument cluster next week would this just plug in and work ok until i find someone with VAGCOM to change the mileage ?
  7. rasA4
    3,287
    119
    did you try putting the fuse back to see if anything happens?:eyebrows:
  8. AUDI@WRC
    84
    just took the car for a spin with the fuse out and when i put it back in it has reset it and it now turns off BUT the screen is stll knackered !!
    if i buy i new insrument cluster can i use it without having VAGCOM to change the mileage ?
  9. vw754
    vw754 vorsprung Durch Technik
    2,336
    58
    yes you can.
  10. 205man
    1,072
    14
    yes you can but you will have to get mileage alterted especially if the mileage on the new clocks is less than the one you have now.
    otherwise the mileage wont tally up with the mileage on your M.O.Ts and service history.
    and would make selling your car difficult and also ilega as milegae would be fraud
    alan
  11. Broken Byzan
    13,237
    465
    Also you need to get the SKC code with the new dash otherwise the imoboliser will kick in
  12. Lowlife
    Lowlife German Hardcore
    568
    Its not illegal its only fraud if you claim that is the genuine mileage...
  13. 205man
    1,072
    14
    yeah thats what i meant to say
    alan
  14. shineydave
    shineydave Member
    920
    you can only change the mileage on a cluster with Vag-Com if the mileage is less than 100 miles so driving with the new cluster in might not be a good idea, if you go over the magic ton you're fecked. so saying that there are specialists out there who can change the mileage but they use specific software to do it and it'll cost you.
  15. PhilR
    PhilR One Ate Tea
    332
    Forgive me if im being stupid, but why can't you just change the DIS screen from the new clocks and keep the rest of your cluster
  16. Broken Byzan
    13,237
    465
    Thats what i aim to do, but the soldering skills required to swap them over is beyond me, i will pay someone to swap them over when i swap the engines,should save taking her off the road twice then
  17. AUDI@WRC
    84
    any idea how much it will cost to get the mileage changed ? changing just the screen looks a big job !
  18. shineydave
    shineydave Member
    920
    changing the screen has been discussed many times on several forums and the opinion is it's not worth the hassle because of the soldering skill required
  19. SamDude
    SamDude Active Member
    2,102
    KITT LIVES!!!
  20. rasA4
    3,287
    119
