Urgent help needed, Audi a3 2.0 tdi sline 2004
cheeco Jul 31, 2012
  1. cheeco
    cheeco New Member
    Has any one had any problems when the car is at idle and its coughing/missing ,when cold but almost gets fine when car is fully warmed.
  2. max69vk
    max69vk Active Member
    862
    57
    Common fault - First check your fuel filter doesn't need replacing, then find someone with VCDS & get them to check your tosion value (should be 0-0.5 degrees on the BKD engine).
  3. cheeco
    cheeco New Member
    Thanks mate going to check these now and let you know the results.
  4. hades-
    9,481
    646
    check EGR
