URGENT HELP - 1.8T FRONT BEARING CAP SEALENT (WHERE)
AGU-TURBO May 10, 2011
  1. AGU-TURBO
    AGU-TURBO Audi a3 1.8t AGU
    616
    Hi need some help please, on the front bearing cap you are supposed to put sealent on it, But where do you put it e.g at the end's - end and middle - or all over excluding where cam seals sit.
    Any help apreciated
  2. AGU-TURBO
    616
  3. AGU-TURBO
    616
  4. Broken Byzan
    13,237
    466
    Have you thought of a dealer? Surely they would know.
  5. SiGainey
    SiGainey Member
    506
    10
    I didn't put any on mine when I did my cam chain tensioner recently. No leaks either...
  6. AGU-TURBO
    616
  7. Broken Byzan
    13,237
    466
    I always put a smidge in the corners by the bearing caps to head edge. 4 little dots does me
  8. AGU-TURBO
    616
    on the under side of the bearing cap or on the sides? thanks
  9. Broken Byzan
    13,237
    466
    on the sides once caps torqued down, just the corners where the gasket has to do 90 degrees almost
  10. AGU-TURBO
    616
    Ok ill do that then, Many thanks
