Uprated TIP, why?
Ian_83 Dec 19, 2010
  1. Ian_83
    Ian_83 Member
    93
    I see a lot, people are using a new TIP with a FMIC. Is the setup not a typical on these engines? ie: turbo charge pipe into FMIC, FMIC into inlet manifold?
    Seems to be a lot of extra pipes on there? I take it you *need* this pipe, even with a FMIC?
  2. A3 Oly
    A3 Oly Member
    247
    This pipe is the Turbo intake pipe from the airbox/filter. this doesnt go to the IC.
  3. sportstractor
    sportstractor Chugger
    2,709
    clue is in the name.
    These are alot less restrictive than the stock item
  4. Ian_83
    Ian_83 Member
    93
    Ah! I'm at the wrong end (that's what she said) :). ta! :)
  5. <tuffty/>
    21,152
    3,834
    On K04 turbo'd engines (S3, TT and LCR) the OEM TIP is prone to collapsing and as seen on Welly's S3 with a hybrid K04 will cavitate as it struggles to draw air through it.... a silicon TIP won't collapse like the OEM one and especially once remapped the engine will generate more heat whilst trying to draw more air so a silicon TIP will help sort that out...
    On a K03 turbo'd engine the TIP is a pile of junk... it has a squashed alloy end that fits to the turbo and small bore inlet beyond that... silicon tip on these supplement a remap...
    If you need more proof of the benefits of changing the TIP, have a read of this...
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/109356-3inch-tip-tests-danes-s3-today.html
  6. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    I would highly recommend a silicone TIP. Definitely made a difference on mine when i got one on. Spool up was quicker and sound got louder. Going to redline felt loads better with no sluggish feel like the standard TIP.
  7. badger5
    9,471
    1,988
    3inch for the win.. hehe
  8. Ian_83
    Ian_83 Member
    93
    Looks like some nice gains up top, strange with the loss of torque lower down. Then again, the new map sorted that out massively :). I take it a 3 inch TIP is too large for my car? 1.8t AGU.
  9. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    :yes:
  10. S3BAM
    S3BAM Member
    362
    Shame u missed my Forge Tip Group buy
    U will require a FM180IND for yours(If u went for Forge Tip)
    Sadly all i have left are FM225IND(S3 FIT) In Black or Red(From non payers)
    They were £108 delivered or £100 collected
    I may see if i can do another in the New Year
