Uprated intercooler
Redbul89 Dec 14, 2013
  1. Redbul89
    Redbul89 New Member
    Hi there I was wondering if anyone knows a good place to get a uprated intercooler for a audi a3 2.0tdi 170 s line?
  2. kimhemm
    kimhemm Member
    66
    I think that THS makes one that should be fine
  3. JJ.Foulds
    JJ.Foulds Well-Known Member
    1,263
    176
    I think thats the best one available that goes in the OEM place!
  4. manor13
    manor13 Active Member
    726
    110
    43
    not sure about the diesel but on the 2.0tfsi we changed to the S3 Oem fitting
  5. flying oyster
    flying oyster flying oyster
    563
    27
    s3 intercooler slots in old ones place just have to change the boost pipes fitting or you could buy a hardpipe kit from darkside also they do intercooler for 250
    in my experience unless your running 300 bhp plus the stock intercooler is man enough for the job
  6. Bagley-S3
    Bagley-S3 Member
    58
    I've just put a pro alloy in my S3 and haven't yet got around to advertising the standard one. Would make a great value for money upgrade. £250 posted if your interested and I'm 95% sure it will bolt into the OEM hole and you will just need to adapt the boost pipes or like above buy a Darkside hardpipe kit,
    Craig :icon_thumright:
  7. hollows wife
    hollows wife Well-Known Member
    1,404
    163
    why would you need an uprated cooler ? standard one is good for 240 bhp.
  8. manor13
    726
    110
    43
    from what i have seen its a pre 2009 S3 as the new ones have plastic end tanks
  9. kimhemm
    kimhemm Member
    66
    It's not always about how much power you CAN make on the old intercooler. But a better intercooler with less pressure drop will make more power with the same map and the turbo will last longer
  10. TDI140
    TDI140 Well-Known Member
    1,632
    174
    I have an s3 one to go in my car next year will fit it in the summer due to **** weather now, also mainly bought it as its a decent upgrade and my stock cooler has oil deposit in it due to turbo blowing earlier this year, car will benefit from egr delete ive been told when installing a bigger cooler but wont see much power gains unless your running bigger turbo and other supporting mods
  11. TDI140
    1,632
    174
    Also intake temps will be lower etc with bugger cooler allowing the car to function more efficiently so over all its a big thumbs up
  12. TDI140
    1,632
    174
    Bigger* sorry for mis typing words im on iphone
  13. TDI140
    1,632
    174
    Picture of rear due to oil in intercooler this is two weeks worth lol
  14. hollows wife
    1,404
    163
    true but speaking from experience i used to own a 140 with standard front mount and hybrid this was mapped to 231 bhp ,limiting factor was injectors not the cooler and egt's were fine .
    you also have to think audi spend millions up millions on development im sure there coolers are as efficient as possible ,the s3 one maybe a good upgrade but i wouldnt go aftermarket.
  15. kimhemm
    kimhemm Member
    66
    Audi will only put an intercooler on the car that works well enough for the power that it makes stock. And if you really believe that Audi have made the best solution to the car/engine, why did you put another turbo on the car :icon_thumright:
    It could be that the injectors was the limit on your car, but a better intercooler will always be good on a turbo charged engine allowing you to make the same power with less boost
    TDI140 likes this.
