Uprated Clutch?
chrisash32 Jun 6, 2011
  1. chrisash32
    chrisash32 Member
    573
    Hi Everyone.
    Clutch started slipping on my A4 over the weekend.
    Its a 1.9TDi running at around 165hp currently with 112k on the clock.
    My question is, should i fit an uprated replacement clutch and if so what should I go for?
    Secondly, is it usual practice to replace the flywheel at the same time on these?
    Thanks!
  2. hades-
    9,482
    646
    well with the power your running id stick with oem maybe sachs
    you will have to let the mech look at flywheel may not need changeing but at 112k id change it
  3. PhilW
    PhilW Member
    182
    5 or 6 speed?
  4. chrisash32
    chrisash32 Member
    573
    6 speed
  5. ASHIHARA
    ASHIHARA Member
    294
    15
    6 speed clutch is pretty strong and is bigger like 5speed clutch(240mm vs 288mm),can hold more than 400nm torque safe;so stick with oem :icon_thumright:
