Uprated Alternator For Audi A4 B5
ZeroK66 Nov 21, 2006
  1. ZeroK66
    ZeroK66 Member
    256
    Hi Guys,
    How/Where can I get one? My motor will be out soon, so be a good idea to it at the same time.
    cheers
  2. ZeroK66
    ZeroK66 Member
    256
    I have tried an A8 one which is 150A but did not fit... trying a TDI one next.
  3. madvw
    madvw Active Member
    2,489
    i'd guess that the diesel one would be the largest you could go without a specialised one.
  4. Broken Byzan
    13,237
    465
    I have a 120 amp TDi one to go on mine when i drop the turbo motor in, it looks at first glance as tho it will fit without to much problem,other than maybe taking a lug off the alternator annd fitting a spacer to the rear mount
  5. AndyMac
    9,832
    46
    My standard A4 2.8Q is 120amp
  6. ZeroK66
    ZeroK66 Member
    256
    Yeah the 2.7T is 120A as well... probably ample for any reasonalbe size setup (aiming for 1500W RMS currently) - but still, while the engine is out I may as well get a new one in there and an upgraded one while I am at it :p
  7. ZeroK66
    ZeroK66 Member
    256
    Apparently the TDI one will fit... so watch this space.
    I am running 4awg cable from the alternator - battery. Multiple earth straps from the engine to the chassis and 0awg cable from the battery earth to the chassis. That should solve any current flow issues I have.
    Will report back and let you know if it has solved my dimming issues. Last thing needed is newer battery and a nice monoblock :D
  8. ZeroK66
    ZeroK66 Member
    256
    Ended up running 0awg cable from the alternator to the battery :). Running 0awg from the battery -ve to the earth too... so there should be ample cable in place.
    Not sure if I am going to see any benifit from the TDI alternator... as this could also be 120A :( - and probably cost me a bomb! either way... I got a nice shiny new alternator in there, some good hardcore cabling ready for a nice install once i get some money in the bank again.
    Cheers,
  9. ZeroK66
    ZeroK66 Member
    256
    Well the latest report is WOW - what a difference. The sound from my standard amp is MUCH improved. That is only pulling about 6-800W at the time. Upgrading the wiring I think made the biggest difference. This is a very worthwhile upgrade if you are running a few hundrew Watt :)
