Upper suspension arm how lon to replace?
Alsie Feb 4, 2012
  1. Alsie
    Alsie Member
    133
    Think someone's taking the mickey, how long should a garage take to change one? Roughly
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,165
    1,124
    Not a clue but I think you have to drop the top mounts to slide the bolts out to remove the arm.
  3. paul20v
    paul20v Audi fanatic
    1,114
    as above also the pinch bolt generally is siezed in and bends through the clamps and can be a ****** to remove also new pinch bolt is required
    When i do them i always change both the front and rear one as you have already done most of the work
    Time wise it dependes on the pinch bolt and the person doing it so i would estimate 1 to 2hrs per side .
  4. Alsie
    Alsie Member
    133
    Would 3 hours be excessive?
  5. ScottD3
    15,165
    1,124
    Depends on what issues they get when doing it.
    Have you got this done, getting a quote or its in at the moment?
    Look at doing a full kit. Makes life a bit easier and you only have to fanny about with the front arms every couple of years depending on the make and miles.
  6. Nessy
    Nessy VW + Audi mad
    959
    93
    The pinch-bolt can be a right swine to remove if they haven't been disturbed in a long time.....
    The 1st time I had to replace an upper suspension arm no amount of heat would unseize the bolt.
    In the end the whole suspension leg had to come out (complete with arms) for it to be drilled out etc.....
    Now I slap loads of copper grease on those bolts whenever I get the chance, and have had no probs since, its a lousy design IMHO.
  7. murran
    murran Well-Known Member
    1,545
    39
    the top pinch bolt secures both top arms to the carrier/upright. due to it carrier being ally and the bolt being steel they can seize in like theyve been welded there.
    theyre a total nightmare. plus the top strut/arm carrier needs unbolting to get the bolts out of the arm bushing.
    3 hours isnt excessive if the jobs turned into a ball ache!!
    ive been there and got the t-shirt in doing these, being a vag specialist mech.
  8. Alsie
    Alsie Member
    133
    Ok cheers guys :) it was 3 hours with 1 hour free from a club discount so much happier now
  9. aragorn
    18,611
    871
    Most B5's have steel uprights, not alloy, but that doesnt change anything, the steel bolt just nicely rusts into the steel upright and effectively welds itself together.
    When i did the bearings on the A4 a few months back i spent nearly an hour drilling the bloody pinch bolt out on one of the uprights alone, so 3 hours for the whole job on both sides isnt outrageous.
  10. murran
    1,545
    39
    later a4 b6/b7s ones are alloy and if anything theyre worse than b5s.
  11. aragorn
    18,611
    871
    Yeh B5 RS4 and some late S4's got alloy ones too. I think the other issue with them is you cant really be quite as rough with heat/hammers etc on the alloy ones. I think mark on here managed to break one a while ago trying to get the bolt out of an alloy upright.
  12. NineNails
    NineNails Proud sponsor of the snack food industry
    593
    Those pinch bolts... Are they just a normal nut and bolt or are they tapered or anything like that?
  13. aragorn
    18,611
    871
    Standard 8.8 grade nut/bolt.
    My replacements were baught from ebay:
    eBay - The UK's Online Marketplace
    Ideally you want to swap the nuts for nylocs or other locking nuts though.
  14. spartacus 68
    spartacus 68 Active Member quattro Audi A2 Audi Avant Owner Group
    391
    61
    Worth lubing the pinch bolt with decent marine grease or copper-ease annually - which would mean replacing it. Had the same problem myself last year. No amount of heat or hitting it would work, so got the mechanic at my work who put it on ramps - so it was at the right height. Lot easier to hit it and it and it eventually shifted. Audi and VW main dealers and specialist independents use this VAS6085, REMOVAL TOOL VAS6085 ... but I've read they can fail too!
  15. aragorn
    18,611
    871
    Why replace it? Its not a torque to yeild fastener, you can reuse it just fine.
