Upper shocker bolts
mattyb6 Jun 27, 2013
  1. mattyb6
    mattyb6 Active Member
    977
    75
    When I had my coilovers fitted, the rear shock absorber bolts went in fine. But the one of the top ones snapped inside the hole.
    Just recently this has caused a really bad knocking where the top mount is spinning round and hitting the inner wheel arch.
    ha anyone had one of these bolts snap and of so how did there fix it?
    i think il have to drill it out and re tap the hole
  2. Audi Doodah
    Audi Doodah Active Member
    377
    35
    Sounds a bit dangerous, having the top mount only secured with one bolt!?!? Fair bit of movement there!
    Defo a big enough diameter on the bolt to get an Ezy-Out kit in there...saves re-tapping then. Part number for the bolt is 907 583 01, £1.17 each +VAT.
  3. mattyb6
    977
    75
    Its fairly secure on all fairness but it does new doing.
    What is an Ezy out kit?
    And do you think it will be pain in the backside?
    Il pop to the dealers and get a new bolt.
  4. Audi Doodah
    377
    35
  5. mattyb6
    977
    75
    Canny bit if of kit that like mate, and for £8 is worth it for the future.
    the bolt is fine I believe.
    Well it's getting full new arms this weekend and rs4 ARB so il get this done too.
    cheers fella
  6. Audi Doodah
    377
    35
    Won't be the best out there but should suffice for the home mechanic.
    Good mod the RS4 ARB. Stops my Avant cornering like a canal barge! :yes:
  7. mattyb6
    977
    75
    Hahaha.
    mines getting some tlc this weekend. Feeling sorry for itself.
    tbh I either do 17mile trip on a motorway twice a day. So rs4 ARB is pointless. BUT I can go a different way, through country lanes and old pit villages. Which as you probably know can be a bit fun to drive ;) (told our lass I need it though)
    swarcup and Audi Doodah like this.
  8. swarcup
    swarcup Well-Known Member
    1,326
    40
    go for it, when I did mine it was like night and day. love it
  9. mattyb6
    977
    75
    Prices are £100 plus brackets etc
    plus £300 plus vat for control arms.
    Going to be an expensive day tomorrow.
  10. Andie0
    Andie0 Member
    490
    13
    You can put a nut over the top weld in the centre of it to the broken bolt then undo with a socket bit over top once cold
  11. mattyb6
    977
    75
    Never thought of that. Il take the shocker off and have a good look
