upgrading to TT brakes
Discussion in 'A3/S3 Forum (8L Chassis)' started by kenny15, Oct 5, 2003.
  1. kenny15
    kenny15 Member
    May 29, 2003
    32
    Just wondering is the brake calipers off a 225 TT is the same as a A3 TSport and if so did anybody know the part nos. for the bracket that hold the calipers.
    cheer
  2. Advert Guest Advertisement
  3. nfluester
    nfluester Member
    Oct 9, 2003
    60
    Can someone who's done this mod give a description of the improvement over standard 288MM disk on the 1.8T?
    does it make a noticeable difference for the money? or is it worth saving the money for some brembo GTs
  4. cpt_splash
    cpt_splash New Member
    Jul 4, 2003
    Hi,
    I have a '98 A3 1.8T Sport, and just recently had the brakes upgraded by AmD. I had TT calipers and EBC grooved discs and greenstuff pads fitted. The difference is chalk and cheese. The feel from the standard brakes was a bit spongy and in a emergency did not inspire real confidence. The new set-up is sooooooo much better. Real feel in the pedal and shorter stopping distances. AmD charged £209 for the discs, £64 for the pads, £185 for the calipers plus fitting at £55 per hour. I had a chip, service and rolling road so don't know the exact labour cost, but 1 hour would be enough. I would definately recommend this mod, it feal much much better. Hope this helps. Graham
  5. nfluester
    nfluester Member
    Oct 9, 2003
    60
    That's great, any ideas why they changed the Calipers as well?
    I was under inpression that the calipers are the same and I only needed the Carriers and disks or can someone correct me.
