Upgrading to RS4 (B5) Brakes
silversurfer Jul 30, 2010
  1. silversurfer
    silversurfer Member
    223
    Hi,
    Just a quick question
    If I upgarde my A4 1.8T Quattro brakes to RS4 (B5) disc's, pads and calipers, will I have to upgarde the brake servo and master cylinder.?
    Thanks in advance for any help.
    Neil
  2. scott b
    scott b Active Member VCDS Map User
    1,254
    ive put the S4 321mm set up on mine, didnt bother with the servo/master cylinder, but you may need spacers
  3. J7USS
    J7USS Shuddup Foooool!!
    3,737
    76
    No servo or master cylinder upgrade needed but like scott says, you may need spacers depending on what wheels you are running.
  4. Broken Byzan
    13,237
    465
    As above.
    The wheel choice is the important one due to the offet and spoke shape.
  5. docurley
    4,070
    85
    You might need the brake lines too but no need to upgrade the brake servo but 18" wheels will be needed.
  6. scott b
    1,254
    i used the b6 brake lines on mine
  7. Avant4me
    Avant4me The're Graphite not black!!
    257
    Does your car have 312mm discs? if so i will happily buy your caliper carriers for mine. Let me know
    Matt
